Rendering and managing spherical data with sphere quadtrees, Proceedings of the 1st Conference on Visualization '90. VIS '90, pp.176-186, 1990. ,
The design and use of steerable filters, IEEE Trans. Pattern Anal. Mach. Intell, vol.13, issue.9, pp.891-906, 1991. ,
Adaptive manifolds for real-time high-dimensional filtering, ACM TOG, vol.31, issue.13, pp.1-33, 2012. ,
Efficient reflectance and visibility approximations for environment map rendering, Computer Graphics Forum, vol.26, pp.495-502, 2007. ,
The irradiance volume, IEEE Comput. Graph. Appl, vol.18, issue.2, pp.32-43, 1998. ,
Healpix: A framework for high-resolution discretization and fast analysis of data distributed on the sphere, The Astrophysical Journal, vol.622, p.759, 2005. ,
Frequency domain normal map filtering, ACM Transactions on Graphics, vol.26, p.12, 2007. ,
Realistic, hardware-accelerated shading and lighting, Proceedings of the 26th Annual Conference on Computer Graphics and Interactive Techniques. SIGGRAPH '99, pp.171-178, 1999. ,
The theory of spherical and ellipsoidal harmonics. The University press, 1931. ,
Advanced environment mapping in vr applications, Computers and Graphics, vol.28, pp.99-104, 2004. ,
Fast, arbitrary brdf shading for low-frequency lighting using spherical harmonics, Proceedings of the 13th Eurographics Workshop on Rendering. EGRW '02. Eurographics Association, pp.291-296, 2002. ,
Metric-aware processing of spherical imagery, ACM SIGGRAPH Asia 2010 Papers. SIGGRAPH ASIA '10, vol.149, pp.1-149, 2010. ,
Distributed gradient-domain processing of planar and spherical images, ACM Trans. Graph, vol.29, issue.2, p.11, 2010. ,
Real-time shading with filtered importance sampling, Computer Graphics Forum -CGF, vol.27, pp.1147-1154, 2008. ,
Efficient and accurate rotation of finite spherical harmonics expansions, Journal of Computational Physics, vol.231, pp.243-250, 2012. ,
Real-time triple product relighting using spherical local-frame parameterization, The Visual Computer, vol.22, pp.682-692, 2006. ,
A Wavelet Tour of Signal Processing, The Sparse Way, 2008. ,
, Directional Statistics. Wiley Series in Probability and Statistics, 2009.
A data-driven reflectance model, ACM Transactions on Graphics, vol.22, pp.759-769, 2003. ,
Homomorphic factorization of brdfs for high-performance rendering, Proceedings of the 28th Annual Conference on Computer Graphics and Interactive Techniques. SIGGRAPH '01, pp.171-178, 2001. ,
Simple and table feline: Fast elliptical lines for anisotropic texture mapping, 1999. ,
Illumination and reflection maps: Simulated objects in real and simulated environment, 1984. ,
All-frequency shadows using non-linear wavelet lighting approximation, ACM SIG-GRAPH 2003 Papers. SIGGRAPH '03, pp.376-381, 2003. ,
Triple product wavelet integrals for all-frequency relighting, ACM SIGGRAPH 2004 Papers. SIGGRAPH '04, pp.477-487, 2004. ,
Sparse zonal harmonic factorization for efficient sh rotation, ACM Transactions on Graphics, vol.31, pp.1-9, 2012. ,
An efficient representation for irradiance environment maps, Proceedings of the 28th annual conference on Computer graphics and interactive techniques. SIG-GRAPH '01, pp.497-500, 2001. ,
Frequency space environment map rendering, ACM Trans. Graph, vol.21, pp.517-526, 2002. ,
A signal-processing framework for reflection, ACM Trans. Graph, vol.23, issue.4, pp.1004-1042, 2004. ,
Spherical wavelets: efficiently representing functions on the sphere, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques. SIG-GRAPH '95, pp.161-172, 1995. ,
Stupid spherical harmonics (sh) tricks, 2008. ,
Precomputed radiance transfer for real-time rendering in dynamic, low-frequency lighting environments, ACM Trans. Graph, vol.21, pp.527-536, 2002. ,
Radially-symmetric reflection maps, SIGGRAPH 2009: Talks. SIGGRAPH '09, vol.24, pp.1-24, 2009. ,
Isocube: Exploiting the cubemap hardware, IEEE Trans. Vis. Comput. Graph, vol.13, pp.720-731, 2007. ,
Allfrequency rendering of dynamic, spatially-varying reflectance, ACM Trans. Graph, vol.28, issue.10, pp.1-133, 2009. ,
Sparse reconstruction by separable approximation, Trans. Sig. Proc, vol.57, pp.2479-2493, 2009. ,
Spherical piecewise constant basis functions for all-frequency precomputed radiance transfer, IEEE Transactions on Visualization and Computer Graphics, vol.14, pp.454-467, 2008. ,
Anisotropic spherical gaussians, ACM Trans. Graph, vol.32, issue.6, p.11, 2013. ,
