Link Quality Estimation with the Gilbert-Elliot Model for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ana Bildea
  • Fonction : Auteur
  • PersonId : 940800
Olivier Alphand
Franck Rousseau
Andrzej Duda
In this paper, we apply the Gilbert-Elliot model to analyze measurements on a large-scale wireless sensor testbed with nodes equipped with CC1101 and CC2420 radio chips. The model considers a packet loss process as a sequence of transitions between Good and Bad states. We analyze the Packet Reception Ratio (PRR) based on the probabilities derived from the Gilbert-Elliot model. We show that the probabilities and other parameters (run and loss lengths) can very well discriminate between the main categories of link quality such as good and weak links. Identification of link quality is crucial for routing protocols such as RPL and LOADng.
bildea-pimrc15.pdf (597.7 Ko) Télécharger le fichier
hal-01188270 , version 1 (28-02-2018)
Ana Bildea, Olivier Alphand, Franck Rousseau, Andrzej Duda. Link Quality Estimation with the Gilbert-Elliot Model for Wireless Sensor Networks. International Symposium on Personal, Indoor and Mobile Radio Communications (PIMRC 2015), Aug 2015, Hong-Kong, China. ⟨10.1109/PIMRC.2015.7343635⟩. ⟨hal-01188270⟩
163 Consultations
947 Téléchargements
