A Parametric Replay-Based Framework for Underwater Acoustic Communication Channel Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper lays the foundation of an underwater acoustic channel simulation methodology that is halfway between parametric modeling and stochastic replay of at-sea measurements of channel impulse responses. The motivation behind this approach is to extend the scope of use of replay-based methods by allowing some parameterization of the channel properties while complying with some level of realism. Based on a relative entropy minimization between the original channel impulse response and the simulated one, the idea is to deliberately distort the original channel statistics in order to meet some specified constraints.
UComms_socheleau_et_al_final.pdf (233.18 Ko) Télécharger le fichier
hal-01188803 , version 1 (31-08-2015)
François-Xavier Socheleau, Christophe Laot, Jean-Michel Passerieux. A Parametric Replay-Based Framework for Underwater Acoustic Communication Channel Simulation. UComms 2014 : Underwater Communications and networking, Sep 2014, Sestri Levante, Italy. ⟨10.1109/UComms.2014.7017148⟩. ⟨hal-01188803⟩
100 Consultations
295 Téléchargements
