Improving depth perception during surgical augmented reality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study suggests a method to compensate the loss of depth perception while enhancing organ vessels and tumors to surgeons. This method relies on a combination of contour rendering technique and adaptive alpha blending to effectively perceive the vessels and tumors depth. In addition, this technique is designed to achieve real-time to satisfy the requirements of clinical routines, and has been tested on real human surgery.
template.pdf (5.73 Mo) Télécharger le fichier
Format : Figure, Image
hal-01191101 , version 1 (01-09-2015)
Bruno Marques, Nazim Haouchine, Rosalie Plantefeve, Stephane Cotin. Improving depth perception during surgical augmented reality. SIGGRAPH [Poster], Aug 2015, Los Angeles, United States. pp.Article No. 24, ⟨10.1145/2787626.2792654⟩. ⟨hal-01191101⟩
291 Consultations
286 Téléchargements
