Termination of rewrite relations on λ-terms based on Girard's notion of reducibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2015
In this paper, we show how to extend the notion of reducibility introduced by Girard for proving the termination of β-reduction in the polymorphic λ-calculus, to prove the termination of various kinds of rewrite relations on λ-terms, including rewriting modulo some equational theory and rewriting with matching modulo βη, by using the notion of computability closure. This provides a powerful termination criterion for various higher-order rewriting frameworks, including Klop's Combinatory Reductions Systems with simple types and Nipkow's Higher-order Rewrite Systems.
main.pdf (658.73 Ko) Télécharger le fichier
hal-01191693 , version 1 (02-09-2015)
Frédéric Blanqui. Termination of rewrite relations on λ-terms based on Girard's notion of reducibility. Theoretical Computer Science, 2015, 611 (50-86), pp.37. ⟨10.1016/j.tcs.2015.07.045⟩. ⟨hal-01191693⟩
Collections
INRIA INRIA2
147 Consultations
118 Téléchargements
