New interface
Journal articles
Mollification in strongly Lipschitz domains with application to continuous and discrete de rham complexes
Abstract : We construct mollification operators in strongly Lipschitz domains that do not invoke non-trivial extensions, are L p stable for any real number p ∈ [1, ∞], and commute with the differential operators ∇, ∇×, and ∇·. We also construct mollification operators satisfying boundary conditions and use them to characterize the kernel of traces related to the tangential and normal trace of vector fields. We use the mollification operators to build projection operators onto general H 1-, H(curl)-and H(div)-conforming finite element spaces, with and without homogeneous boundary conditions. These operators commute with the differential operators ∇, ∇×, and ∇·, are L p-stable, and have optimal approximation properties on smooth functions.
Document type :
Journal articles
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01192941
Contributor : Alexandre Ern Connect in order to contact the contributor
Submitted on : Friday, April 6, 2018 - 1:01:55 PM
Last modification on : Friday, November 18, 2022 - 9:27:03 AM
File
smoothing.pdf
Identifiers
Collections
Citation
Alexandre Ern, Jean-Luc Guermond. Mollification in strongly Lipschitz domains with application to continuous and discrete de rham complexes. Computational Methods in Applied Mathematics, 2016, 16 (1), pp.51-75. ⟨10.1515/cmam-2015-0034⟩. ⟨hal-01192941v2⟩
Share
Metrics
Record views
302
Files downloads
499
