Multi-Agent Only Knowing on Planet Kripke
The idea of only knowing is a natural and intuitive notion to precisely capture the beliefs of a knowledge base. However, an extension to the many agent case, as would be needed in many applications , has been shown to be far from straightforward. For example, previous Kripke frame-based accounts appeal to proof-theoretic constructions like canonical models, while more recent works in the area abandoned Kripke semantics entirely. We propose a new account based on Moss' characteristic formulas, formulated for the usual Kripke semantics. This is shown to come with other benefits: the logic admits a group version of only knowing , and an operator for assessing the epistemic en-trenchment of what an agent or a group only knows is definable. Finally, the multi-agent only knowing operator is shown to be expressible with the cover modality of classical modal logic, which then allows us to obtain a completeness result for a fragment of the logic.
