Validating Dominator Trees for a Fast, Verified Dominance Test
Sandrine Blazy 1 Delphine Demange 1 David Pichardie 1
1 CELTIQUE - Software certification with semantic analysis
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
Abstract : The problem of computing dominators in a control flow graph is central to numerous modern compiler optimizations. Many efficient algorithms have been proposed in the litterature, but mechanizing the correctness of the most sophisticated algorithms is still considered as too hard problems, and to this date, verified compilers use less optimized implementations. In contrast, production compilers, like GCC or LLVM, implement the classic, efficient Lengauer-Tarjan algorithm [12], to compute dominator trees. And subsequent optimization phases can then determine whether a CFG node dominates another node in constant time by using their respective depth-first search numbers in the dominator tree. In this work, we aim at integrating such techniques in verified compilers. We present a formally verified validator of untrusted dominator trees, on top of which we implement and prove correct a fast dominance test following these principles. We conduct our formal development in the Coq proof assistant, and integrate it in the middle-end of the CompCertSSA verified compiler. We also provide experimental results showing performance improvement over previous formalizations.
Type de document :
Communication dans un congrès
Springer. Interactive Theorem Proving, Aug 2015, Nanjing, China. Lecture Notes in Computer Science (LNCS) (9236), 2015, Interactive Theorem Proving - 6th International Conference, ITP 2015. 〈10.1007/978-3-319-22102-1_6〉
Liste complète des métadonnées
Littérature citée [20 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01193281
Contributeur : Sandrine Blazy <>
Soumis le : vendredi 4 septembre 2015 - 16:57:22
Dernière modification le : mercredi 21 novembre 2018 - 13:56:58
Document(s) archivé(s) le : samedi 5 décembre 2015 - 13:49:08
Fichier
main.pdf
Fichiers produits par l'(les) auteur(s)
Distributed under a Creative Commons Paternité 4.0 International License
Citation
Sandrine Blazy, Delphine Demange, David Pichardie. Validating Dominator Trees for a Fast, Verified Dominance Test. Springer. Interactive Theorem Proving, Aug 2015, Nanjing, China. Lecture Notes in Computer Science (LNCS) (9236), 2015, Interactive Theorem Proving - 6th International Conference, ITP 2015. 〈10.1007/978-3-319-22102-1_6〉. 〈hal-01193281〉
Métriques
Consultations de la notice
1056
Téléchargements de fichiers
112
