Chaotic stirring by a mesoscale surface-ocean flow, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.12, issue.2, pp.373-381, 2002. ,
DOI : 10.1063/1.1481615
Importance of stirring in the development of an ironfertilized phytoplankton bloom, Nature, pp.407-727, 2000. ,
Lagrangian reconstructions of temperature and velocity in a model of surface ocean turbulence, Ocean Modelling, pp.59-71, 2014. ,
Statistical mechanics of two-dimensional and geophysical flows, Physics Reports, vol.515, issue.5, pp.227-295, 2012. ,
DOI : 10.1016/j.physrep.2012.02.001
URL : https://hal.archives-ouvertes.fr/hal-00636610
A gridded sea surface salinity dataset for the tropical Pacific with sample applications, Deep-Sea Research 1045 I, pp.38-48, 1950. ,
Emerging ocean observations for interdisciplinary data assimilation systems, Journal of Marine Systems, vol.40, issue.41, pp.40-41, 2003. ,
DOI : 10.1016/S0924-7963(03)00011-3
Guide to best practices for ocean CO2 measurements, 1050. ,
The Operational Sea Surface Temperature and Sea Ice Analysis (OSTIA) system, Remote Sensing of Environment, pp.140-158, 2012. ,
Air-sea CO2 fluxes above the stratified oxygen minimum zone in the coastal region off Mexico, J. Geophys. Res. Oceans, vol.119, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01011732
Turbulence: The Legacy of A, N. Kolgomorov, 1995. ,
Modeling of atmospheric transport of chemical species in the polar regions, 2012 IEEE International Geoscience and Remote Sensing Symposium, p.1065 ,
DOI : 10.1109/IGARSS.2012.6352228
Transport at the Air? Sea Interface ? Measurements, Models and Parameterizations, pp.978-981, 2007. ,
Transfer Across the Air-Sea Interface, Ocean?Atmosphere Interactions of Gases and Particles, pp.55-112, 2014. ,
DOI : 10.1007/978-3-642-25643-1_2
Seasonal variability of f CO2 in the Angola-Benguela region, Progress in Oceanography, vol.83, pp.1-4, 2009. ,
Coupled physical/biogeochemical modeling including O2-dependent processes in the Eastern Boundary Upwelling Systems: application in the Benguela, Biogeosciences, vol.10, pp.3559-3591, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00949573
Atmospheric CO2 uptake 1095 by a coastal upwelling system, Global Biogeochem. Cycles, vol.19, 1009. ,
The oceanic Vertical Pump Induced by 1100 ,
Recent variability of the global ocean carbon sink, Global Biogeochemical Cycles, vol.31, issue.5958, pp.927-949, 2014. ,
DOI : 10.1002/2014GB004853
: What does it respond to?, Global Biogeochemical Cycles, vol.350, issue.19, p.1017, 2004. ,
DOI : 10.1029/2003GB002102
Edges, transitions and criticality, Pattern Recognition, vol.47, issue.6, pp.2104-2115, 2014. ,
DOI : 10.1016/j.patcog.2013.12.013
URL : https://hal.archives-ouvertes.fr/hal-00924137
Consistent merging of satellite ocean color data sets using a bio-optical model, Remote Sensing of Environment, vol.94, issue.4, pp.429-440, 2005. ,
DOI : 10.1016/j.rse.2004.08.014
Eastern boundary currents: The Benguela Current System, in: Carbon and Nutrient Fluxes in Continental Margins: 1115 A Global Synthesis, 2010. ,
High-resolution modeling of the Eastern Tropical Pacific Oxygen Minimum Zone: Sensitivity to the 1120 tropical oceanic circulation, Journal of Geophysical, 2014. ,
The oxygen minimum zone (OMZ) off Chile as intense source of CO2 and N2O, Continental Shelf Research, vol.28, issue.20, pp.2746-2756, 2008. ,
DOI : 10.1016/j.csr.2008.09.012
URL : https://hal.archives-ouvertes.fr/hal-00402563
An atmospheric perspective on North American carbon dioxide exchange : CarbonTracker, Proceedings of the National Academy of Sciences of the USA, pp.925-943, 2007. ,
ON OPTIMAL WAVELET BASES FOR THE REALIZATION OF MICROCANONICAL CASCADE PROCESSES, International Journal of Wavelets, Multiresolution and Information Processing, vol.09, issue.01 ,
DOI : 10.1142/S0219691311003943
URL : https://hal.archives-ouvertes.fr/inria-00582372
An Optimized Algorithm for the Evaluation of Local Singularity Exponents in Digital Signals, LNCS 6636 of 14th International Workshop on Combinatorial Image Analysis, 1160. ,
DOI : 10.1088/1751-8113/41/1/015501
URL : https://hal.archives-ouvertes.fr/inria-00581057
Inferring mising data in satellite chlorophyll maps using turbulent cascading, pp.4242-4260, 2008. ,
Interannual sea?air CO2 flux variability from an observationdriven ocean mixed-layer scheme, Biogeosciences, vol.284, issue.11, pp.4599-4613, 1165. ,
Carbon dioxide fluxes in the Benguela upwelling system during winter 1190 and spring: A comparison between, Deep Sea Research Part II, vol.56, pp.8-10, 2005. ,
Terra and Aqua MODIS products available from NASA GES DAAC, Advances in Space Research, vol.1195, pp.34-710, 2004. ,
Ocean turbulent dynamics at super resolution from optimal multiresolution analysis and multiplicative cascade, IEEE TGRS, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01354909
Constraining global air-sea gas exchange for CO2 with recent bomb 14C measurements, Global Biogeochemical Cycles, vol.21, p.2015, 2007. ,
Global sea-air CO2 flux based on climatological surface ocean pCO2, and seasonal biological and temperature effects, Deep-Sea Research II, pp.1601-1622, 2002. ,
Estimating the monthly <i>p</i>CO<sub>2</sub> distribution in the North Atlantic using a self-organizing neural network, Biogeosciences Discussions, vol.6, issue.2, pp.3373-3414, 2009. ,
DOI : 10.5194/bgd-6-3373-2009
Multifractal Method for the Instantaneous Evaluation of the Stream Function in Geophysical Flows, Physical Review Letters, vol.95, issue.10, p.502, 1230. ,
DOI : 10.1103/PhysRevLett.95.104502
Microcanonical multifractal formalism???a geometrical approach to multifractal systems: Part I. Singularity analysis, Journal of Physics A: Mathematical and Theoretical, vol.41, issue.1, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00937370
in a simplified biogeochemical offline model, Tellus B: Chemical and Physical Meteorology, vol.49, issue.5, pp.821-840, 2010. ,
DOI : 10.1111/j.1600-0889.2010.00495.x
Carbon export and sequestration in the southern Benguela upwelling system: lower and upper estimates, Ocean Science, vol.5, issue.4, pp.711-718, 2009. ,
DOI : 10.5194/os-5-711-2009
Carbon dioxide in water and seawater: the solubility of a non-ideal gas, Marine Chemistry, vol.2, issue.3, pp.203-215, 1974. ,
DOI : 10.1016/0304-4203(74)90015-2
Motion analysis in 1245 oceanographic satellite images using multiscale methods and the energy cascade, Pattern Recognition, issue.10, pp.43-3591, 2010. ,
