Dynamic Programming, 1957. ,
Probability and Measure, 1986. ,
Randomization of Number Theoretic Methods for Multiple Integration, SIAM Journal on Numerical Analysis, vol.13, issue.6, p.904914, 1976. ,
DOI : 10.1137/0713071
Machine Learning Solution Methods for Multistage Stochastic Programming, 2010. ,
The ???Pegasus??? method for computing the root of an equation, BIT, vol.11, issue.4, pp.503-508, 1972. ,
DOI : 10.1007/BF01932959
Scenario reduction in stochastic programming: An approach using probability metrics, 20 in Stochastic Programming E-Print Series, Institut fr Mathematik, 2000. ,
Continuous functions minimization by dynamic random search technique, Applied Mathematical Modelling, vol.31, issue.10, pp.2189-2198, 2007. ,
DOI : 10.1016/j.apm.2006.08.015
Monte-Carlo Simulation Balancing in Practice, Computers and Games, pp.81-92, 2010. ,
DOI : 10.1007/978-3-642-17928-0_8
Simulation-Based Optimization with Stochastic Approximation Using Common Random Numbers, Management Science, vol.45, issue.11, pp.1570-1578, 1999. ,
DOI : 10.1287/mnsc.45.11.1570
Optimal stratification using random search method in agricultural surveys, Statistics in Transition, vol.6, issue.5, pp.797-806, 2004. ,
On the stratification of skewed populations, Survey Methodology, vol.14, issue.1, pp.33-43, 1988. ,
The empirical behavior of sampling methods for stochastic programming, Annals of Operations Research, vol.29, issue.1, pp.215-241, 2006. ,
DOI : 10.1007/s10479-006-6169-8
On the scrambled halton sequence. Monte-Carlo Methods Appl, pp.435-442, 2004. ,
Improving the performance of Stochastic Dual Dynamic Programming, Journal of Computational and Applied Mathematics, vol.290, 2012. ,
DOI : 10.1016/j.cam.2015.04.048
Generating Quasi-Random Paths for Stochastic Processes, SIAM Review, vol.40, issue.4, pp.765-78831795, 1998. ,
DOI : 10.1137/S0036144597317959
Random Number Generation and Quasi-Monte Carlo Methods, 1992. ,
DOI : 10.1137/1.9781611970081
Multi-stage stochastic optimization applied to energy planning, Mathematical Programming, vol.4, issue.1-3, pp.359-375, 1991. ,
DOI : 10.1007/BF01582895
A NOTE ON OPTIMUM STRATIFICATION OF POPULATIONS FOR ESTIMATING THE POPULATION MEANS, Australian Journal of Statistics, vol.Vol. II, issue.1, pp.20-33, 1963. ,
DOI : 10.1111/j.1467-842X.1963.tb00134.x
Risk neutral and risk averse Stochastic Dual Dynamic Programming method, European Journal of Operational Research, vol.224, issue.2, pp.375-391, 2013. ,
DOI : 10.1016/j.ejor.2012.08.022
Differential evolution?a simple and efficient heuristic for global optimization over continuous spaces, Journal of Global Optimization, vol.11, issue.4, pp.341-359, 1997. ,
DOI : 10.1023/A:1008202821328
Policy search using paired comparisons, Journal of Machine Learning Research, vol.3, pp.921-950, 2002. ,
Direct policy search using paired statistical tests, Proceedings of the 18th International Conference on Machine Learning, pp.545-552 ,
Paired comparison-based Interactive Differential Evolution, 2009 World Congress on Nature & Biologically Inspired Computing (NaBIC), pp.475-480, 2009. ,
DOI : 10.1109/NABIC.2009.5393359
URL : https://hal.archives-ouvertes.fr/hal-00480932
Randomized Halton sequences, Mathematical and Computer Modelling, vol.32, issue.7-8, pp.887-899, 2000. ,
DOI : 10.1016/S0895-7177(00)00178-3
URL : http://doi.org/10.1016/s0895-7177(00)00178-3
Random Search Algorithms, Wiley Encyclopedia of Operations Research and Management Science, vol.37, issue.4, 2009. ,
DOI : 10.1002/9780470400531.eorms0704
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.434.3618
