Evolutionary Cutting Planes
The Cutting Plane method is a simple and efficient method for optimizing convex functions in which subgradients are available. This paper proposes several methods for parallelizing it, in particular using a typically evolutionary method, and compares them experimentally in a well-conditioned and ill-conditioned settings.
Optimisation et contrôle [math.OC]
