Analytic Combinatorics of the Mabinogion Urn - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
The Mabinogion urn is a simple model of the spread of influences amongst versatile populations. It corresponds to a non-standard urn with balls of two colours: each time a ball is drawn, it causes a ball of the other kind to switch its colour. The process stops once unanimity has been reached. This note provides analytic expressions describing the evolution of the Mabinogion urn, based on a time-reversal transformation applied to the classical Ehrenfest urn. Consequences include a precise asymptotic analysis of the stopping-time distribution―it is asymptotically normal in the "unfair'' case and akin to an extreme-value (double exponential) distribution in the "fair'' case―as well as a characterization of the exponentially small probability of reversing a majority.
dmAI0138.pdf (722.01 Ko) Télécharger le fichier
hal-01194668 , version 1 (07-09-2015)
Philippe Flajolet, Thierry Huillet. Analytic Combinatorics of the Mabinogion Urn. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.549-572, ⟨10.46298/dmtcs.3591⟩. ⟨hal-01194668⟩
373 Consultations
552 Téléchargements
