Rapid Convergence to Equilibrium of Stochastic Ising Models in the Dobrushin Shlosman Regime, Percolation Theory and Ergodic Theory of Infinite Particle Systems Math. Applic, 1987. ,
DOI : 10.1007/978-1-4613-8734-3_1
Path coupling: A technique for proving rapid mixing in Markov chains, Proceedings 38th Annual Symposium on Foundations of Computer Science, pp.223-231, 1997. ,
DOI : 10.1109/SFCS.1997.646111
Delayed path coupling and generating random permutations via distributed stochastic processes, 10 Ann. Symp. Disc. Alg, ACM-SIAM, pp.355-363, 1999. ,
DOI : 10.1002/1098-2418(200010/12)17:3/4<238::aid-rsa4>3.0.co;2-e
The Mixing Time Evolution of Glauber Dynamics for the Mean-Field Ising Model, Communications in Mathematical Physics, vol.127, issue.2, 2008. ,
DOI : 10.1007/s00220-009-0781-9
Real Analysis and Probability, 1989. ,
DOI : 10.1017/CBO9780511755347
An extension of path coupling and its application to the Glauber dynamics for graph colourings, 11 Ann. Symp. Disc. Alg, ACM-SIAM, pp.616-624, 2000. ,
Very rapid mixing of the Glauber dynamics for proper colorings on bounded-degree graphs, Random Structures and Algorithms, vol.41, issue.1, pp.98-114, 2002. ,
DOI : 10.1002/rsa.10020
An Extension of Path Coupling and Its Application to the Glauber Dynamics for Graph Colorings, SIAM Journal on Computing, vol.30, issue.6, pp.1962-1975, 2001. ,
DOI : 10.1137/S0097539700372708
Chaoticity on path space for a queueing network with selection of the shortest queue among several, Journal of Applied Probability, vol.28, issue.01, pp.198-210, 2000. ,
DOI : 10.1007/BF01199263
Functional central limit theorems for a large network in which customers join the shortest of several queues, Probability Theory and Related Fields, vol.64, issue.1, pp.97-120, 2004. ,
DOI : 10.1007/s00440-004-0372-9
URL : https://hal.archives-ouvertes.fr/hal-00001392
Mathematical foundations of MCMC, Probabilistic Methods for Algorithmic Discrete Mathematics, pp.116-165, 1998. ,
Foundation of kinetic theory, Proc. 3rd Berkeley Symp, pp.171-197, 1956. ,
The Concentration of measure phenomenon, 2001. ,
DOI : 10.1090/surv/089
Glauber dynamics for the mean-field Ising model: cut-off, critical power law, and metastability, Probability Theory and Related Fields, vol.33, issue.2 ,
DOI : 10.1007/s00440-008-0189-z
Transportation cost inequalities for stationary distributions of Markov kernels, 2008. ,
On the power of two choices: Balls and bins in continuous time, The Annals of Applied Probability, vol.15, issue.3, pp.1733-1764, 2005. ,
DOI : 10.1214/105051605000000205
On the maximum queue length in the supermarket model, The Annals of Probability, vol.34, issue.2, pp.493-527, 2006. ,
DOI : 10.1214/00911790500000710
Asymptotic distributions and chaos for the supermarket model, Electronic Journal of Probability, vol.12, issue.0, pp.75-99, 2007. ,
DOI : 10.1214/EJP.v12-391
URL : http://arxiv.org/abs/0712.2091
Strong approximation for the supermarket model, The Annals of Applied Probability, vol.15, issue.3, pp.2038-2061, 2005. ,
DOI : 10.1214/105051605000000368
URL : http://arxiv.org/abs/math/0405183
Markov chains and mixing times, 2009. ,
DOI : 10.1090/mbk/058
The power of two choices in randomized load balancing, IEEE Transactions on Parallel and Distributed Systems, vol.12, issue.10, 1996. ,
DOI : 10.1109/71.963420
Load balancing with memory, The 43rd Annual IEEE Symposium on Foundations of Computer Science, 2002. Proceedings., 2002. ,
DOI : 10.1109/SFCS.2002.1182005
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.6380
The Power of Two Random Choices: A Survey of Techniques and Results, pp.255-312, 2001. ,
DOI : 10.1007/978-1-4615-0013-1_9
Concentration, Probabilistic Methods for Algorithmic Discrete Mathematics, pp.195-248, 1998. ,
DOI : 10.1007/978-3-662-12788-9_6
Very rapidly mixing Markov chains for 2?-colorings and for independent sets in a graph with maximum degree 4, Random Structures and Algorithms, vol.41, issue.2, pp.101-115, 2001. ,
DOI : 10.1002/1098-2418(200103)18:2<101::AID-RSA1000>3.0.CO;2-D
Probability Metrics and the Stability of Stochastic Models, Wiley Series in Probability and Mathematical Statistics: Applied Probability and Statistics, 1991. ,
Topics in propagation of chaos InÉcoleIn´InÉcole d' ´ Eté de Probabilités de Saint-Flour XIX -1989, pp.165-251, 1989. ,
Queueing system with selection of the shortest of two queues: an asymptotic approach, Problems Inform. Transmission, vol.32, pp.15-27, 1996. ,
Mixing in time and space for discrete spin systems, 2004. ,
