A Nonlinear Controller for Parallel Induction Heating Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work develops a nonlinear controller for an induction heating system using a parallel resonant inverter. The proposed controller should be seen as a nonlinear alternative to the standard Phase-locked loop technique which uses a PI regulator. The asymptotic stability of the closed loop system is demonstrated using a Lyapunov function. The controller is experimentally validated and its performances (robustness and disturbance rejection) are compared to those of a PI regulator.
IFAC.pdf (1.16 Mo) Télécharger le fichier
hal-01195543 , version 1 (08-09-2015)
Jonathan Zerad, Samer Riachy, Pierre Toussaint, Jean-Pierre Barbot. A Nonlinear Controller for Parallel Induction Heating Systems. IFAC World Congress 2014, Aug 2014, Cap Town, South Africa. pp.11617-11622, ⟨10.3182/20140824-6-ZA-1003.00311⟩. ⟨hal-01195543⟩
400 Consultations
473 Téléchargements
