FPGA Implementation of a Switching Frequency Modulation Circuit for EMI Reduction in Resonant Inverters for Induction Heating Appliances, IEEE Transactions on Industrial Electronics, vol.55, issue.1, pp.11-20, 2008. ,
DOI : 10.1109/TIE.2007.896129
Finite-time stability of homogeneous systems, Proceedings of the 1997 American Control Conference (Cat. No.97CH36041), 1997. ,
DOI : 10.1109/ACC.1997.609245
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
Monyakul Fullbridge current-fed inverter with automatic frequency control for forging application, Iin Proc. IEEE TEN- CON, vol.4, pp.128-131, 2004. ,
An Improved <formula formulatype="inline"><tex Notation="TeX">$LLC$</tex></formula> Resonant Inverter for Induction-Heating Applications With Asymmetrical Control, IEEE Transactions on Industrial Electronics, vol.58, issue.7, pp.2915-2925, 2011. ,
DOI : 10.1109/TIE.2010.2070779
25-kW/50-kHz generator for induction heating, IEEE Transactions on Industrial Electronics, vol.38, issue.3, pp.203-209, 1991. ,
DOI : 10.1109/41.87588
Principle of a multi-load/single converter system for low power induction heating, IEEE Transactions on Power Electronics, vol.15, issue.2, pp.223-230, 2000. ,
DOI : 10.1109/63.838094
Homogeneous coordinates and continuous asymptotically stabilizing feedback controls, pp.249-260, 1991. ,
DOI : 10.1051/cocv:1997101
URL : http://archive.numdam.org/article/COCV_1997__2__13_0.pdf
Stabilization of nonlinear systems in the plane, Systems & Control Letters, vol.12, issue.2, pp.169-175, 1989. ,
DOI : 10.1016/0167-6911(89)90010-8
Acero Series Resonant Multiinverter with Discontinuous-Mode Control for Improved Light-Load Operation, IEEE Trans. Ind. Electron, vol.58, issue.11, pp.3163-3171, 2011. ,
A Power-Control Scheme With Constant Switching Frequency in Class-D Inverter for Induction-Heating Jar Application, IEEE Transactions on Industrial Electronics, vol.54, issue.3, pp.1252-1260, 2007. ,
DOI : 10.1109/TIE.2007.892741
Dynamic Analysis and Control for Resonant Currents in a Zone-Control Induction Heating System, IEEE Transactions on Power Electronics, vol.28, issue.3, pp.1297-1307, 2013. ,
DOI : 10.1109/TPEL.2012.2210286
The peaking phenomenon and the global stabilization of nonlinear systems, IEEE Transactions on Automatic Control, vol.36, issue.4, pp.424-440, 1991. ,
DOI : 10.1109/9.75101
