Event-triggered observers and observer-based controllers for a class of nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we investigate the stabilization of a nonlinear plant subject to network constraints, under the assumption of partial knowledge of the plant state. The event triggered paradigm is used for the observation and the control of the system. Necessary conditions, making use of the ISS property, are given to guarantee the existence of a triggering mechanism, leading to asymptotic convergence of the observer and system states. The proposed triggering mechanism is illustrated in the stabilization of a robot with a flexible link robot.
nlhal.pdf (414.29 Ko) Télécharger le fichier
hal-01195569 , version 1 (09-09-2015)
Etienne Lucien, Stefano Di Gennaro, Jean-Pierre Barbot. Event-triggered observers and observer-based controllers for a class of nonlinear systems. American Control Conference, Jul 2015, Chicago, United States. ⟨10.1109/ACC.2015.7172072⟩. ⟨hal-01195569⟩
541 Consultations
247 Téléchargements
