Journal articles
Conformal mapping for cavity inverse problem: an explicit reconstruction formula
Abstract : In this paper, we address a classical case of the Calder\'on (or conductivity) inverse problem in dimension two. We aim to recover the location and the shape of a single cavity $\omega$ (with boundary $\gamma$) contained in a domain $\Omega$ (with boundary $\Gamma$) from the knowledge of the Dirichlet-to-Neumann (DtN) map $\Lambda_\gamma: f \longmapsto \partial_n u^f|_{\Gamma}$, where $u^f$ is harmonic in $\Omega\setminus\overline{\omega}$, $u^f|_{\Gamma}=f$ and $u^f|_{\gamma}=c^f$, $c^f$ being the constant such that $\int_{\gamma}\partial_n u^f\,{\rm d}s=0$. We obtain an explicit formula for the complex coefficients $a_m$ arising in the expression of the Riemann map $z\longmapsto a_1 z + a_0 + \sum_{m\leqslant -1} a_m z^{m}$ that conformally maps the exterior of the unit disk onto the exterior of $\omega$. This formula is derived by using two ingredients: a new factorization result of the DtN map and the so-called generalized P\'olia-Szeg\"o tensors (GPST) of the cavity. As a byproduct of our analysis, we also prove the analytic dependence of the coefficients $a_m$ with respect to the DtN. Numerical results are provided to illustrate the efficiency and simplicity of the method.
Document type :
Journal articles
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-01196111
Contributor : Karim Ramdani Connect in order to contact the contributor
Submitted on : Friday, June 24, 2016 - 1:18:05 PM
Last modification on : Friday, July 8, 2022 - 10:08:55 AM
Long-term archiving on: : Sunday, September 25, 2016 - 11:26:05 AM
File
reconstruction_REVISED_HAL.pdf
Identifiers
Collections
Citation
Alexandre Munnier, Karim Ramdani. Conformal mapping for cavity inverse problem: an explicit reconstruction formula. Applicable Analysis, Taylor & Francis, 2016, 96 (1), pp.108-129. ⟨10.1080/00036811.2016.1208816⟩. ⟨hal-01196111v4⟩
Share
Metrics
Record views
282
Files downloads
414
