NOCAS : A Nonlinear Cellular Automata Based Stream Cipher - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2011
LFSR and NFSR are the basic building blocks in almost all the state of the art stream ciphers like Trivium and Grain-128. However, a number of attacks are mounted on these type of ciphers. Cellular Automata (CA) has recently been chosen as a suitable structure for crypto-primitives. In this work, a stream cipher is presented based on hybrid CA. The stream cipher takes 128 bit key and 128 bit initialization vector (IV) as input. It is designed to produce $\mathrm{2^{128}}$ random keystream bits and initialization phase is made faster 4 times than that of Grain-128. We also analyze the cryptographic strength of this cipher. Finally, the proposed cipher is shown to be resistant against known existing attacks.
dmAP0110.pdf (454.52 Ko) Télécharger le fichier
hal-01196137 , version 1 (09-09-2015)
Sandip Karmakar, Dipanwita Roy Chowdhury. NOCAS : A Nonlinear Cellular Automata Based Stream Cipher. 17th International Workshop on Celular Automata and Discrete Complex Systems, 2011, Santiago, Chile. pp.135-146, ⟨10.46298/dmtcs.2970⟩. ⟨hal-01196137⟩
Collections
TDS-MACS
324 Consultations
1140 Téléchargements
