New interface
Journal articles
Designing experiments to discriminate families of logic models
Abstract : Logic models of signaling pathways are a promising way of building effective in silico functional models of a cell, in particular of signaling pathways. The automated learning of Boolean logic models describing signaling pathways can be achieved by training to phosphoproteomics data, which is particularly useful if it is measured upon different combinations of perturbations in a high-throughput fashion. However, in practice, the number and type of allowed perturbations are not exhaustive. Moreover, experimental data are unavoidably subjected to noise. As a result, the learning process results in a family of feasible logical networks rather than in a single model. This family is composed of logic models implementing different internal wirings for the system and therefore the predictions of experiments from this family may present a significant level of variability, and hence uncertainty. In this paper, we introduce a method based on Answer Set Programming to propose an optimal experimental design that aims to narrow down the variability (in terms of input–output behaviors) within families of logical models learned from experimental data. We study how the fitness with respect to the data can be improved after an optimal selection of signaling perturbations and how we learn optimal logic models with minimal number of experiments. The methods are applied on signaling pathways in human liver cells and phosphoproteomics experimental data. Using 25% of the experiments, we obtained logical models with fitness scores (mean square error) 15% close to the ones obtained using all experiments, illustrating the impact that our approach can have on the design of experiments for efficient model calibration.
Document type :
Journal articles
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01196178
Contributor : Anne SIEGEL Connect in order to contact the contributor
Submitted on : Saturday, September 12, 2015 - 11:59:20 AM
Last modification on : Thursday, November 17, 2022 - 4:48:10 PM
Links full text
Identifiers
Citation
Santiago Videla, Irina Konokotina, Leonidas Alexopoulos, Julio Saez-Rodriguez, Torsten Schaub, et al.. Designing experiments to discriminate families of logic models. Frontiers in Bioengineering and Biotechnology, 2015, pp.9. ⟨10.3389/fbioe.2015.00131⟩. ⟨hal-01196178⟩
Share
Metrics
Record views
398
