B??zier surfaces and finite elements for MHD simulations, Journal of Computational Physics, vol.227, issue.16, pp.7423-7445, 2008. ,
DOI : 10.1016/j.jcp.2008.04.001
Isoparametric Bicubic Hermite Elements for Solution of the Grad-Shafranov Equation, International Journal of Modern Physics C, vol.02, issue.01, pp.371-376, 1991. ,
DOI : 10.1142/S0129183191000512
The Finite Element Method for Engineers, 1982. ,
Hierarchical B-spline refinement, Proceedings of the 15th annual conference on Computer graphics and interactive techniques, SIGGRAPH '88, pp.205-212, 1988. ,
DOI : 10.1145/378456.378512
Adaptive and linearly independent multilevel B-splines, Surface Fitting and Multiresolution Methods, pp.209-216 ,
THB-splines: The truncated basis for hierarchical splines, Computer Aided Geometric Design, vol.29, issue.7, pp.485-498, 2012. ,
DOI : 10.1016/j.cagd.2012.03.025
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.257.5553
Polynomial splines over locally refined box-partitions, Computer Aided Geometric Design, vol.30, issue.3, pp.331-356, 2013. ,
DOI : 10.1016/j.cagd.2012.12.005
Curved, isoparametric, ???quadrilateral??? elements for finite element analysis, International Journal of Solids and Structures, vol.4, issue.1, pp.31-42, 1968. ,
DOI : 10.1016/0020-7683(68)90031-0
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.474.903
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.39-41, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
URL : https://hal.archives-ouvertes.fr/hal-01513346
Manifold splines, Graphical Models, vol.68, issue.3, pp.237-254, 2006. ,
DOI : 10.1016/j.gmod.2006.03.004
Manifold T-Spline, Lecture Notes in Computer Science, vol.4077, pp.409-422, 2006. ,
DOI : 10.1007/11802914_29
Polycube splines, Computer-Aided Design, vol.40, issue.6, pp.721-733, 2008. ,
DOI : 10.1016/j.cad.2008.01.012
A simple manifold-based construction of surfaces of arbitrary smoothness, ACM Transactions on Graphics, vol.23, issue.3, pp.271-275, 2004. ,
DOI : 10.1145/1015706.1015714
Subdivision Surfaces, Geometry and Computing, 2008. ,
The S-patch: a new multisided patch scheme, ACM TransGraph, vol.8, pp.204-233, 1989. ,
Visually smooth interpolation with triangular Bézier patches Geometric modeling. Philadelphia: SIAM, p Smooth free-form surfaces over irregular meshes generalizing quadratic splines, Computer Aided Geometric Design, vol.10, pp.221-233, 1987. ,
$C^1 $-Surface Splines, SIAM Journal on Numerical Analysis, vol.32, issue.2, pp.645-666, 1995. ,
DOI : 10.1137/0732029
Recursively generated B-spline surfaces on arbitrary topological meshes, Computer-Aided Design, vol.10, issue.6, pp.350-355, 1978. ,
DOI : 10.1016/0010-4485(78)90110-0
Biquadratic G-spline surfaces, Computer Aided Geometric Design, vol.12, issue.2, pp.193-205, 1995. ,
DOI : 10.1016/0167-8396(94)00009-H
A Refineable Space of Smooth Spline Surfaces of Arbitrary Topological Genus, Journal of Approximation Theory, vol.90, issue.2, pp.174-199, 1997. ,
DOI : 10.1006/jath.1996.3079
Dimensions of spline spaces over T-meshes, Journal of Computational and Applied Mathematics, vol.194, issue.2, pp.267-283, 2006. ,
DOI : 10.1016/j.cam.2005.07.009
Approximation power of polynomial splines on T-meshes, Computer Aided Geometric Design, vol.29, issue.8, pp.599-612 ,
DOI : 10.1016/j.cagd.2012.04.003
Existence of stiffness matrix integrals for singularly parameterized domains in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.49-52, pp.3568-3582, 2011. ,
DOI : 10.1016/j.cma.2011.08.023
Numerical Approximation of Partial Differential Equations, 1997. ,
On Hermite interpolation with polynomial splines on T-meshes, Journal of Computational and Applied Mathematics, vol.240, pp.42-50, 2013. ,
DOI : 10.1016/j.cam.2012.05.018
URL : http://dx.doi.org/10.1016/j.cam.2012.05.018
A fast, high-order solver for the Grad???Shafranov equation, Journal of Computational Physics, vol.243, pp.28-45, 2013. ,
DOI : 10.1016/j.jcp.2013.02.045
On the dimension of spline spaces on planar T-meshes, Mathematics of Computation, vol.83, issue.286, pp.847-871, 2014. ,
DOI : 10.1090/S0025-5718-2013-02738-X
URL : https://hal.archives-ouvertes.fr/inria-00533187
Vidunas and N. Villamizar Dimension and bases for geometrically continuous splines on surfaces of arbitrary topology, Computer Aided Geometric Design, 2016. ,
