H1-parametrizations of complex planar physical domains in Isogeometric analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2017
Isogeometric analysis (IGA) is a method for solving geometric partial differential equations(PDEs). Generating parameterizations of a PDE's physical domain is the basic and important issues within IGA framework. In this paper , we present a global H 1-parameterization method for a planar physical domain with complex topology.
elsarticle-template-num_V_3.pdf (6.76 Mo) Télécharger le fichier
hal-01196435 , version 1 (09-09-2015)
hal-01196435 , version 2 (30-11-2015)
hal-01196435 , version 3 (26-04-2017)
Meng Wu, Bernard Mourrain, André Galligo, Boniface Nkonga. H1-parametrizations of complex planar physical domains in Isogeometric analysis. Computer Methods in Applied Mechanics and Engineering, 2017, 318, pp.296-318. ⟨10.1016/j.cma.2017.01.025⟩. ⟨hal-01196435v3⟩
453 Consultations
290 Téléchargements
