H 1 -parameterizations of plane physical domains with complex topology in Isogeometric analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Isogeometric analysis (IGA) is a method for solving geometric partial differential equations(PDEs). Generating parameterizations of a PDE's physical domain is the basic and important issues within IGA framework. In this paper , we present a global H 1-parameterization method for a planar physical domain with complex topology.
Version_4_PlanarDomainParameterization.pdf (8.41 Mo) Télécharger le fichier
hal-01196435 , version 1 (09-09-2015)
hal-01196435 , version 2 (30-11-2015)
hal-01196435 , version 3 (26-04-2017)
  • HAL Id : hal-01196435 , version 1
Meng Wu, Bernard Mourrain, André Galligo, Boniface Nkonga. H 1 -parameterizations of plane physical domains with complex topology in Isogeometric analysis. 2015. ⟨hal-01196435v1⟩
453 Consultations
290 Téléchargements
