Length thresholds for graphic lists given fixed largest and smallest entries and bounded gaps A simple proof of the Erd? os-Gallai theorem on graph sequences, CM] Grant Cairns and Stacey Mendan. An improvement of a result of Zverovich?Zverovich. Ars Math. Contemp., to appear. [CMN] Grant Cairns, Stacey Mendan, and Yuri Nikolayevsky. A sharp refinement of a result of Zverovich? Zverovich. Discrete Math, pp.1494-150167, 1986. ,
A sharp refinement of a result of Alon, Ben- Shimon and Krivelevich on bipartite graph vertex sequences, Australas. J. Combin, vol.60, issue.2, pp.217-226, 2014. ,
Graph theory, Gal57] David Gale. A theorem on flows in networks, pp.1073-1082, 1957. ,
Handbook of product graphs Boca Raton, FL, second edition Algorithms for constructing graphs and digraphs with given valences and factors, Discrete Mathematics and its ApplicationsBoca Raton Discrete Math, vol.6, pp.79-88, 1973. ,
A remark on degree sequences of multigraphs, Mathematical Methods of Operations Research, vol.6, issue.12???19, pp.369-374, 2009. ,
DOI : 10.1007/s00186-008-0265-2
Combinatorial properties of matrices of zeros and ones. Canad, J. Math, vol.9, pp.371-377, 1957. ,
A simple criterion on degree sequences of graphs, Discrete Applied Mathematics, vol.156, issue.18, pp.3513-3517, 2008. ,
DOI : 10.1016/j.dam.2008.03.033
Jian-Hua Yin. Conditions for r-graphic sequences to be potentially K (r) m+1 -graphic, Erd? os & Gallai. Discrete Math. Discrete Math, vol.265, issue.30921, pp.417-4206271, 2003. ,
Two sufficient conditions for a graphic sequence to have a realization with prescribed clique size, Discrete Math, vol.301, issue.2-3, pp.218-227, 2005. ,
