New interface
Conference papers
Parametric Modeling of the Coupling Parameters of Planar Coupled-Resonator Microwave Filters
Abstract : —The design of planar coupled-resonator microwave filters is widely based on coupling matrix theory. In this framework a coupling matrix is first obtained during the synthesis step. Next this coupling matrix is physically implemented by correctly dimensioning the geometrical parameters of the filter. The implementation step is carried out using simplified empirical design curves relating the coupling coefficients and geometrical parameters. The curves typically only provide initial values and EM optimization is often needed such that the filter response meets the specifications. This paper proposes to extract paramet-ric models that relate the filters design parameters directly to the coupling parameters. The advantage of such models is that they allow to tune the filter in a numerically cheap way and that they provide physical insight in the filters behavior. This paper explains how such models can be extracted from EM simulations and illustrates the technique for the design of an 8 pole cascaded quadruplet filter in a microstrip technology.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01197117
Contributor : Martine Olivi Connect in order to contact the contributor
Submitted on : Friday, September 11, 2015 - 11:02:37 AM
Last modification on : Saturday, June 25, 2022 - 11:16:55 PM
Long-term archiving on: : Tuesday, December 29, 2015 - 12:25:09 AM
File
EUMW15_Final.pdf
Identifiers
Collections
Citation
Matthias Caenepeel, Fabien Seyfert, Yves Rolain, Martine Olivi. Parametric Modeling of the Coupling Parameters of Planar Coupled-Resonator Microwave Filters. Microwave Conference (EuMC 2015), Sep 2015, Paris, France. pp.4, ⟨10.1109/EuMC.2015.7345819⟩. ⟨hal-01197117⟩
Share
Metrics
Record views
136
Files downloads
514
