Scientific Data Sharing and Re-use - Introduction to the Special Theme
Research data are essential to all scientific endeavours. Openness in the sharing of research results is one of the norms of modern science. The assumption behind this openness is that scientific progress requires results to be shared within the scientific community as early as possible in the discovery process.
100-13.pdf (4 Ko)
Télécharger le fichier
100-13.citations-grobid.bib (4 Ko)
