The dynamics of montmorillonite clay dispersion and morphology development in immiscible ethylene???propylene rubber/polypropylene blends, Polymer, vol.48, issue.15, pp.4520-4528, 2007. ,
DOI : 10.1016/j.polymer.2007.05.068
-propylene) Rubber Blends, Macromolecules, vol.37, issue.7, pp.2454-2459, 2004. ,
DOI : 10.1021/ma0352072
URL : https://hal.archives-ouvertes.fr/hal-00938395
Compatibilizing Bulk Polymer Blends by Using Organoclays, Macromolecules, vol.39, issue.14, pp.4793-4801, 2006. ,
DOI : 10.1021/ma060125+
Interlayer Structure and Molecular Environment of Alkylammonium Layered Silicates, Chemistry of Materials, vol.6, issue.7, pp.1017-1022, 1994. ,
DOI : 10.1021/cm00043a025
Twenty Years of Polymer-Clay Nanocomposites, Macromolecular Materials and Engineering, vol.78, issue.281, pp.1449-1476, 2006. ,
DOI : 10.1002/mame.200600260
Polymer matrix degradation and color formation in melt processed nylon 6/clay nanocomposites, Polymer, vol.44, issue.24, pp.7545-7556, 2003. ,
DOI : 10.1016/j.polymer.2003.09.034
Polymer/montmorillonite nanocomposites with improved thermal properties, Thermochimica Acta, vol.453, issue.2, pp.75-96, 2007. ,
DOI : 10.1016/j.tca.2006.11.002
Thermal Degradation Chemistry of Alkyl Quaternary Ammonium Montmorillonite, Chemistry of Materials, vol.13, issue.9, pp.2979-2990, 2001. ,
DOI : 10.1021/cm010305s
Thermal degradation of commercially available organoclays studied by TGA???FTIR, Thermochimica Acta, vol.457, issue.1-2, pp.92-102, 2007. ,
DOI : 10.1016/j.tca.2007.03.008
Preparation and characterization of nylon 11/organoclay nanocomposites, Polymer, vol.44, issue.12, pp.3529-3535, 2003. ,
DOI : 10.1016/S0032-3861(03)00252-0
Water-assisted melt compounding of nylon-6/pristine montmorillonite nanocomposites, Journal of Polymer Science Part B: Polymer Physics, vol.42, issue.9, pp.1100-1112, 2005. ,
DOI : 10.1002/polb.20397
Flavour retention during high temperature short time extrusion cooking process: a review, International Journal of Food Science and Technology, vol.25, issue.5, pp.453-461, 2001. ,
DOI : 10.1021/jf9808372
Reinforcement and environmental degradation of nylon-6/clay nanocomposites, Polymer, vol.42, issue.13, pp.5849-5858, 2001. ,
DOI : 10.1016/S0032-3861(00)00900-9
Determination of the surface area of smectite in water by ethylene oxide chain adsorption, Journal of Colloid and Interface Science, vol.285, issue.2, pp.443-447, 2005. ,
DOI : 10.1016/j.jcis.2004.12.056
Adsorption Mechanism(s) of Poly(Ethylene Oxide) on Oxide Surfaces, Journal of Colloid and Interface Science, vol.196, issue.1, pp.92-98, 1997. ,
DOI : 10.1006/jcis.1997.5192
Adsorption of poly(ethylene oxide) on smectite: Effect of layer charge, Journal of Colloid and Interface Science, vol.332, issue.1, pp.11-15, 2009. ,
DOI : 10.1016/j.jcis.2008.12.024
Inferring meaningful relaxation spectra from experimental data, Journal of Rheology, vol.58, issue.3, pp.779-797, 2014. ,
DOI : 10.1122/1.4870967
The way to measure quantitatively full dissolution and crystallization of polyamides in water up to 200??C and above by DSC, Thermochimica Acta, vol.453, issue.1, pp.67-71, 2007. ,
DOI : 10.1016/j.tca.2006.10.020
Crystallization and dissolution behaviour of polyamide 6-water systems under pressure, Polymer International, vol.233, issue.1, pp.119-125, 2011. ,
DOI : 10.1002/pi.2920
Melting point of polymers under high pressure, Thermochimica Acta, vol.424, issue.1-2, pp.175-181, 2004. ,
DOI : 10.1016/j.tca.2004.05.025
Crystallization of polyamides under elevated pressure: 2. Pressure-induced crystallization of nylon-6 (polycapramide) from the melt, Polymer, vol.16, issue.9, pp.673-679, 1975. ,
DOI : 10.1016/0032-3861(75)90075-0
Dissolution of Hydrogen-Bonded Polymers in Water:?? A Study of Nylon-4,6, Macromolecules, vol.37, issue.24, pp.8825-8828, 2004. ,
DOI : 10.1021/ma0483423
Linear rheological behaviour and thermal stability of poly(butylene terephthalate)/epoxy/clay ternary nanocomposites, Polymer Degradation and Stability, vol.87, issue.3, pp.511-519, 2005. ,
DOI : 10.1016/j.polymdegradstab.2004.10.008
On the Structure and Properties of Polyamides. XXVII. The Mechanism of Water Sorption in Polyamides, Journal of Polymer Science Part C: Polymer Symposia, vol.29, issue.1, pp.79-93, 1967. ,
DOI : 10.1002/polc.5070160109
Migration of nanosilica particles in polymer blends, Journal of Polymer Science Part B: Polymer Physics, vol.15, issue.109, pp.1976-1983, 2008. ,
DOI : 10.1002/polb.21534
URL : https://hal.archives-ouvertes.fr/hal-00373896
A method to control the dispersion of carbon black in an immiscible polymer blend, Polymer Engineering & Science, vol.14, issue.5, pp.1058-1063, 2003. ,
DOI : 10.1002/pen.10089
Montmorillonite Fillers, Chemistry of Materials, vol.15, issue.4, pp.844-849, 2003. ,
DOI : 10.1021/cm0212865
Computer simulation of nylon-6/organoclay nanocomposites: prediction of the binding energy, Fluid Phase Equilibria, vol.212, issue.1-2, pp.315-329, 2003. ,
DOI : 10.1016/S0378-3812(03)00273-5
Predicting the binding energy for nylon 6,6/clay nanocomposites by molecular modeling, Polymer, vol.43, issue.2, pp.541-553, 2002. ,
DOI : 10.1016/S1089-3156(01)00014-9
The mechanism of adsorption of poly(ethylene oxide) flocculant on silica, Journal of Colloid and Interface Science, vol.57, issue.1, pp.132-142, 1976. ,
DOI : 10.1016/0021-9797(76)90182-X
Factors influencing encapsulation behavior in composite droplet-type polymer blends, Polymer, vol.44, issue.1, pp.49-59, 2003. ,
DOI : 10.1016/S0032-3861(02)00684-5
Morphology-processing relationships in polyethylene-polyamide blends, Polymer Engineering and Science, vol.26, issue.9, pp.553-565, 1990. ,
DOI : 10.1002/pen.760300908
Influence of elasticity on dispersed-phase droplet size in immiscible polymer blends in simple shearing flow, Polymer Engineering & Science, vol.41, issue.4, pp.798-809, 2002. ,
DOI : 10.1002/pen.10992
Abstracts of Papers of the, pp.493-493, 2002. ,
Nylon 6 nanocomposites: the effect of matrix molecular weight, Polymer, vol.42, issue.25, pp.9929-9940, 2001. ,
DOI : 10.1016/S0032-3861(01)00552-3
A Rheological Study on the Kinetics of Hybrid Formation in Polypropylene Nanocomposites, Macromolecules, vol.34, issue.4, pp.852-858, 2001. ,
DOI : 10.1021/ma000565f
Van Gurp-Palmen Plot II - classification of long chain branched polymers by their topology, Rheologica Acta, vol.41, issue.1-2, pp.103-113, 2002. ,
DOI : 10.1007/s003970200010
Masterbatch-based multi-walled carbon nanotube filled polypropylene nanocomposites: Assessment of rheological and mechanical properties, Composites Science and Technology, vol.69, issue.11-12, pp.1756-1763, 2009. ,
DOI : 10.1016/j.compscitech.2008.10.005
Preparation and Rheological Characterization of Polymer Nanocomposites Based on Expanded Graphite, Journal of Macromolecular Science, Part A, vol.58, issue.6, pp.591-598, 2007. ,
DOI : 10.1016/j.polymer.2003.12.013
Immiscible Blends of PC and PET, Current Knowledge and New Results: Rheological Properties, Macromolecular Materials and Engineering, vol.44, issue.204, pp.693-706, 2007. ,
DOI : 10.1002/mame.200700006
URL : https://hal.archives-ouvertes.fr/hal-00372767
Phase Behavior and its Viscoelastic Responses of Poly(methyl methacrylate) and Poly(styrene-co-maleic anhydride) Blend Systems, Polymer Bulletin, vol.56, issue.4-5, pp.455-466, 2006. ,
DOI : 10.1007/s00289-005-0499-6
A generalized relation between MWD and relaxation time spectrum, Rheologica Acta, vol.27, issue.5-6, pp.509-519, 2008. ,
DOI : 10.1007/s00397-007-0228-1
Determination of the relaxation spectrum by a regularization method, Macromolecules, vol.22, issue.11, pp.4372-4377, 1989. ,
DOI : 10.1021/ma00201a036
Rheological, morphological, and interfacial properties of compatibilized PLA/PBAT blends, Rheologica Acta, vol.28, issue.8, pp.501-517, 2014. ,
DOI : 10.1007/s00397-014-0774-2
URL : https://hal.archives-ouvertes.fr/hal-00998957
Nanosize and microsize clay effects on the kinetics of the thermal degradation of polylactides, Polymer Degradation and Stability, vol.94, issue.3, pp.327-338, 2009. ,
DOI : 10.1016/j.polymdegradstab.2008.12.009
Relations between structure and property of polyamide 11 nanocomposites based on raw clays elaborated by water-assisted extrusion, Journal of Applied Polymer Science, vol.37, issue.6, pp.4809-4824, 2013. ,
DOI : 10.1002/app.38053
New insights into the hydrolytic degradation of poly(lactic acid): participation of the alcohol terminus, Polymer, vol.42, issue.7, pp.2795-2802, 2001. ,
DOI : 10.1016/S0032-3861(00)00646-7
Synthesis of exfoliated polyamide 6,6/organically modified montmorillonite nanocomposites by in situ interfacial polymerization, Polymer Composites, vol.44, issue.6, pp.733-738, 2007. ,
DOI : 10.1002/pc.20360
Thermal stability and flammability of polypropylene/montmorillonite composites, Polymer Degradation and Stability, vol.85, issue.2, pp.807-813, 2004. ,
DOI : 10.1016/j.polymdegradstab.2004.03.014
