Conference papers
Stokes polyhedra for $X$-shaped polyminos
Abstract : Consider a pair of $\textit{interlacing regular convex polygons}$, each with $2(n + 2)$ vertices, which we will be referring to as $\textit{red}$ and $\textit{black}$ ones. One can place these vertices on the unit circle $|z | = 1$ in the complex plane; the vertices of the red polygon at $\epsilon^{2k}, k = 0, \ldots , 2n − 1$, of the black polygon at $\epsilon^{2k+1}, k = 0, \ldots , 2n − 1$; here $\epsilon = \exp(i \pi /(2n + 2))$. We assign to the vertices of each polygon alternating (within each polygon) signs. Note that all the pairwise intersections of red and black sides are oriented consistently. We declare the corresponding orientation positive.
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01197226
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Friday, September 11, 2015 - 12:54:46 PM
Last modification on : Thursday, August 1, 2019 - 2:12:06 PM
Long-term archiving on: : Tuesday, December 29, 2015 - 12:33:13 AM
File
dmAQ0127.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Yu. Baryshnikov, L. Hickok, N. Orlow, S. Son. Stokes polyhedra for $X$-shaped polyminos. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), 2012, Montreal, Canada. pp.361-364, ⟨10.46298/dmtcs.3005⟩. ⟨hal-01197226⟩
Share
Metrics
Record views
60
Files downloads
443
