Support Vector Machines for Multiple-Instance Learning, NIPS, pp.561-568, 2002. ,
, Multi-Instance Tree Learning. ICML, pp.57-64, 2005.
Relational Learning as Search in a Critical Region, Journal of Machine Learning Research, vol.4, pp.431-463, 2003. ,
Where the Really Hard Problems are, IJCAI, pp.331-337, 1991. ,
Image Categorization by Learning and Reasoning with Regions, Journal of Machine Learning Research, vol.5, pp.913-939, 2004. ,
Solving Multiple-Instance and Multiple-Part Learning Problems with Decision Trees and Rule Sets. Application to the Mutagenesis Problem, Canadian Conference on Artificial Intelligence, pp.204-214, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-01571852
Torch: a Modular Machine Learning Software Library, 2002. ,
, Semigroup Kernels on Finite Sets. NIPS, pp.329-336, 2004.
Solving the Multiple-Instance Problem with Axis-Parallel Rectangles, Artificial Intelligence, vol.89, issue.1-2, pp.31-71, 1997. ,
, , pp.179-186, 2002.
, Phase Transitions in Relational Learning. Machine Learning, vol.41, pp.217-251, 2000.
Phase Transitions and the Search Problem, Artificial intelligence, vol.81, issue.1-2, pp.1-15, 1996. ,
Learning in the Presence of Malicious Errors, SIAM J. Comput, vol.22, pp.807-837, 1993. ,
Propositionalization Approaches to Relational Data Mining, Relational data mining, pp.262-291, 2001. ,
, Marginalized Multi-Instance Kernels. IJCAI, pp.901-906, 2007.
The Pharmacophore Kernel for Virtual Screening with Support Vector Machines, Journal of Chemical Information and Modeling, vol.46, pp.2003-2014, 2006. ,
A Framework for Multiple-Instance Learning, NIPS, pp.570-576, 1997. ,
Inductive Logic Programming: Theory and Methods, Journal of Logic Programming, vol.19, pp.629-679, 1994. ,
Phase Transitions Within Grammatical Inference, IJCAI, pp.811-816, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02482160
, Statistical Learning Theory, 1998.
A Two level Learning Method for Generalized Multi-Instance Problems, ECML, pp.468-479, 2003. ,
EM-DD: A Improved Multiple-Instance Learning Technique, NIPS, pp.1073-1080, 2001. ,
