Design of continuous–discrete observers for time-varying nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2015
We present a new design for continuous-discrete observers for a large class of continuous time nonlinear time-varying systems with discrete time measurements. Using the notion of cooperative systems, we show that the solutions of the observers converge to the solutions of the original system, under conditions on the nonlinear terms and on the largest sampling interval. Our conditions are given by explicit expressions.
Automatique
7April2015AutomaticaTemplate.pdf (455.04 Ko) Télécharger le fichier
hal-01198426 , version 1 (12-09-2015)
Frederic Mazenc, Vincent Andrieu, Michael Malisoff. Design of continuous–discrete observers for time-varying nonlinear systems. Automatica, 2015, pp.10. ⟨10.1016/j.automatica.2015.04.016⟩. ⟨hal-01198426⟩
269 Consultations
496 Téléchargements
