Single Base Modular Multiplication for Efficient Hardware RNS Implementations of ECC
The paper describes a new RNS modular multiplication algorithm for efficient implementations of ECC over FP. Thanks to the proposition of RNS-friendly Mersenne-like primes, the proposed RNS algorithm requires 2 times less moduli than the state-of-art ones, leading to 4 times less precomputations and about 2 times less operations. FPGA implementations of our algorithm are presented, with area reduced up to 46 %, for a time overhead less than 10 %.
