Power-aware microarchitecture: Design and modeling challenges for next-generation microprocessors, IEEE Micro, vol.20, issue.6, pp.26-44, 2000. ,
Near-Threshold Computing: Reclaiming Moore's Law Through Energy Efficient Integrated Circuits, Proceedings of the IEEE, pp.253-266, 2010. ,
DOI : 10.1109/JPROC.2009.2034764
Razor: circuit-level correction of timing errors for low-power operation, IEEE Micro, vol.24, issue.6, pp.10-20, 2004. ,
DOI : 10.1109/MM.2004.85
Algorithm-based fault tolerance for matrix operations, IEEE Trans. Comput, vol.33, issue.6, pp.518-528, 1984. ,
Voltage over-scaling: A cross-layer design perspective for energy efficient systems, 2011 20th European Conference on Circuit Theory and Design (ECCTD), pp.548-551, 2011. ,
DOI : 10.1109/ECCTD.2011.6043592
Adaptive voltage over-scaling for resilient applications, 2011 Design, Automation & Test in Europe, pp.1-6, 2011. ,
DOI : 10.1109/DATE.2011.5763153
Multiple frequency selection in DVFS-enabled processors to minimize energy consumption, Energy-Efficient Distributed Computing Systems, 2012. ,
CAS-FEST 2010: Mitigating Variability in Near-Threshold Computing, IEEE Journal on Emerging and Selected Topics in Circuits and Systems, vol.1, issue.1, pp.42-49, 2011. ,
DOI : 10.1109/JETCAS.2011.2135550
Embedding fault-tolerance, exploiting approximate computing and retaining high performance in the matrix multiplication, Workshop On Approximate Computing (WAPCO), 2015. ,
