Abstract : MPI is the most widely used parallel programming model. But the reducing amount of memory per compute core tends to push MPI to be mixed with shared-memory approaches like OpenMP. In such cases, the interoperability of those two models is challenging. The MPI 2.0 standard defines the so-called thread level to indicate how MPI will interact with threads. But even if hybrid programs are more common, there is still a lack in debugging tools and more precisely in thread level compliance. To fill this gap, we propose a static analysis to verify the thread-level required by an application. This work extends PARCOACH, a GCC plugin focused on the detection of MPI collective errors in MPI and MPI+OpenMP programs. We validated our analysis on computational benchmarks and applications and measured a low overhead.
