MPI Thread-Level Checking for MPI+OpenMP Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
MPI is the most widely used parallel programming model. But the reducing amount of memory per compute core tends to push MPI to be mixed with shared-memory approaches like OpenMP. In such cases, the interoperability of those two models is challenging. The MPI 2.0 standard defines the so-called thread level to indicate how MPI will interact with threads. But even if hybrid programs are more common, there is still a lack in debugging tools and more precisely in thread level compliance. To fill this gap, we propose a static analysis to verify the thread-level required by an application. This work extends PARCOACH, a GCC plugin focused on the detection of MPI collective errors in MPI and MPI+OpenMP programs. We validated our analysis on computational benchmarks and applications and measured a low overhead.
parcoach_EuroPar_camera_ready.pdf (222.42 Ko) Télécharger le fichier
hal-01199718 , version 1 (15-09-2015)
Emmanuelle Saillard, Patrick Carribault, Denis Barthou. MPI Thread-Level Checking for MPI+OpenMP Applications. Euro-Par 2015, Aug 2015, Vienne, Austria. pp.31-42, ⟨10.1007/978-3-662-48096-0_3⟩. ⟨hal-01199718⟩
Collections
CEA CNRS DAM
218 Consultations
384 Téléchargements
