Dynamics of pattern formation in lateral-inhibition type neural fields, Biological Cybernetics, vol.13, issue.2, pp.77-87, 1977. ,
DOI : 10.1007/BF00337259
Two-dimensional saccade-related population activity in superior colliculus in monkey, Journal of Neurophysiology, vol.80, issue.2, pp.798-817, 1998. ,
A model of the saccade-generating system that accounts for trajectory variations produced by competing visual stimuli, Biological Cybernetics, vol.92, issue.1, pp.21-37, 2005. ,
DOI : 10.1007/s00422-004-0526-y
Twodimensional neural networks model of the primate saccadis system, Neural Networks, vol.7, pp.6-71115, 1994. ,
Decoding of a motor command vector from distributed activity in superior colliculus, Biological Cybernetics, vol.86, issue.3, pp.179-189, 2002. ,
DOI : 10.1007/s00422-001-0288-8
Disinhibition as a basic process in the expression of striatal functions. I. The striato-nigral influence on tecto-spinal/tecto-diencephalic neurons, Brain Research, vol.334, issue.2, pp.215-226, 1985. ,
DOI : 10.1016/0006-8993(85)90213-6
EFFECT OF NON-TARGET STIMULI UPON LENGTH OF VOLUNTARY SACCADES, Perceptual and Motor Skills, vol.2, issue.2, pp.499-508, 1972. ,
DOI : 10.2466/pms.1972.34.2.499
Human cortical magnification factor and its relation to visual acuity, Experimental Brain Research, vol.21, issue.5, pp.447-454, 1974. ,
DOI : 10.1007/BF00237163
The representation of the visual field on the cerebral cortex in monkeys, The Journal of Physiology, vol.159, issue.2, pp.203-221, 1961. ,
DOI : 10.1113/jphysiol.1961.sp006803
The Evaluation of the Oculomotor Error Signal, Theoretical and applied aspects of eye movement research, pp.55-62, 1984. ,
DOI : 10.1016/S0166-4115(08)61818-X
Competitive Integration of Visual and Preparatory Signals in the Superior Colliculus during Saccadic Programming, Journal of Neuroscience, vol.27, issue.19, pp.5053-5062, 2007. ,
DOI : 10.1523/JNEUROSCI.4212-06.2007
A neural network model of sensoritopic maps with predictive short-term memory properties., Proceedings of the National Academy of Sciences, vol.88, issue.21, pp.9653-9657, 1991. ,
DOI : 10.1073/pnas.88.21.9653
Global visual processing for saccadic eye movements Visual information for saccadic eye movements Activity of cells in the deeper layers of the superior colliculus of the rhesus monkey: evidence for a gaze displacement command, Vision Research Findlay JM Sparks DL Journal of Neurophysiology, vol.78, issue.3, pp.1669-1690, 1982. ,
A neural model of saccadic eye movement control explains task-specific adaptation, Vision Research, vol.39, issue.18, pp.3123-3143, 1999. ,
DOI : 10.1016/S0042-6989(99)00049-8
Motor Functions of the Superior Colliculus, Annual Review of Neuroscience, vol.34, issue.1, pp.205-231, 2011. ,
DOI : 10.1146/annurev-neuro-061010-113728
Programming of endogenous and exogenous saccades: Evidence for a competitive integration model., Journal of Experimental Psychology: Human Perception and Performance, vol.28, issue.5, pp.1038-1054, 2002. ,
DOI : 10.1037/0096-1523.28.5.1039
Visual Fixation as Equilibrium: Evidence from Superior Colliculus Inactivation, Journal of Neuroscience, vol.32, issue.31, pp.10627-10636, 2012. ,
DOI : 10.1523/JNEUROSCI.0696-12.2012
URL : https://hal.archives-ouvertes.fr/hal-01427763
Dynamic Ensemble Coding of Saccades in the Monkey Superior Colliculus, Journal of Neurophysiology, vol.95, issue.4, pp.2326-2341, 2006. ,
DOI : 10.1152/jn.00889.2005
Goal Representations Dominate Superior Colliculus Activity during Extrafoveal Tracking, Journal of Neuroscience, vol.28, issue.38, pp.9426-9439, 2008. ,
DOI : 10.1523/JNEUROSCI.1313-08.2008
Superior Colliculus Inactivation Causes Stable Offsets in Eye Position during Tracking, Journal of Neuroscience, vol.28, issue.32, pp.8124-8137, 2008. ,
DOI : 10.1523/JNEUROSCI.1317-08.2008
URL : https://hal.archives-ouvertes.fr/hal-01427871
Permitted and Forbidden Sets in Symmetric Threshold-Linear Networks, Neural Computation, vol.13, issue.3, pp.621-638, 2003. ,
DOI : 10.1162/089976602760408008
Modification of saccadic eye movements by gaba-related substances . i. effect of muscimol and bicuculline in monkey superior colliculus, Journal of Neurophysiology, vol.53, issue.1, pp.266-291, 1985. ,
Visual and oculomotor functions of monkey substantia nigra pars reticulata. iv. relation of substantia nigra to superior colliculus, Journal of Neurophysiology, vol.49, issue.5, pp.1285-1301, 1983. ,
The remote distractor effect of saccade latencies in fixation-offset and overlap conditions2773?2779 Johnston A (1986) A spatial property of the retinocortical mapping, Vision Research Spatial Vision, vol.45, issue.14, pp.319-331, 2005. ,
Properties of saccade-related neurons in the cat superior colliculus: patterns of movement fields and discharge timing, Experimental Brain Research, vol.131, issue.2, pp.149-164, 2000. ,
DOI : 10.1007/s002219900265
Population coding of saccadic eye movements by neurons in the superior colliculus, Nature, vol.332, issue.6162, pp.357-360, 1988. ,
DOI : 10.1038/332357a0
An In Vitro Study of Horizontal Connections in the Intermediate Layer of the Superior Colliculus, Journal of Neuroscience, vol.26, issue.18, pp.4763-4768, 2006. ,
DOI : 10.1523/JNEUROSCI.0724-06.2006
Dynamic feedback to the superior colliculus in a neural network model of the gaze control system, Neural Networks, vol.5, issue.6, pp.871-890, 1992. ,
DOI : 10.1016/S0893-6080(05)80084-X
Distributed model of control of saccades by superior colliculus and cerebellum, Neural Networks, vol.11, issue.7-8, pp.1175-1190, 1998. ,
DOI : 10.1016/S0893-6080(98)00071-9
D??termination et latence de la r??ponse oculomotrice ?? deux stimulus simultan??s ou successifs selon leur excentricit?? relative, L'ann??e psychologique, vol.69, issue.2, pp.373-392, 1969. ,
DOI : 10.3406/psy.1969.27671
Le champ d'activit?? du regard : donn??es exp??rimentales, L'ann??e psychologique, vol.74, issue.1, pp.43-65, 1974. ,
DOI : 10.3406/psy.1974.28023
Spatial Relationships of Visuomotor Transformations in the Superior Colliculus Map, Journal of Neurophysiology, vol.100, issue.5, pp.2564-2576, 2008. ,
DOI : 10.1152/jn.90688.2008
Spatial Interactions in the Superior Colliculus Predict Saccade Behavior in a Neural Field Model, Journal of Cognitive Neuroscience, vol.3, issue.2, pp.315-336, 2012. ,
DOI : 10.1007/s00221-006-0532-5
Large receptive fields and spatial transformations in the visual system, International Review of Physiology, vol.10, pp.223-248, 1976. ,
Intrinsic circuitry of the superior colliculus: pharmacophysiological identification of horizontally oriented inhibitory interneurons, Journal of Neurophysiology, vol.79, issue.3, pp.1597-1602, 1998. ,
Functional imaging of the primate superior colliculus during saccades to visual targets, Nature Neuroscience, vol.4, issue.10, pp.1026-1031, 2001. ,
DOI : 10.1038/nn727
Lateral inhibitory interactions in the intermediate layers of the monkey superior colliculus, Journal of Neurophysiology, vol.79, pp.1193-1209, 1998. ,
Saccade-related activity in monkey superior colliculus. i. characteristics of burst and buildup cells, Journal of Neurophysiology, vol.73, pp.2313-2333, 1995. ,
Saccade-Related Spread of Activity Across Superior Colliculus May Arise From Asymmetry of Internal Connections, Journal of Neurophysiology, vol.96, issue.2, pp.765-777, 2006. ,
DOI : 10.1152/jn.01372.2005
Scanpaths in Eye Movements during Pattern Perception, Science, vol.171, issue.3968, pp.308-311, 1971. ,
DOI : 10.1126/science.171.3968.308
Comparison of the distribution and somatodendritic morphology of tectotectal neurons in the cat and monkey, Visual Neuroscience, vol.15, issue.5, pp.903-922, 1998. ,
DOI : 10.1017/S095252389815513X
Lateral interactions in the superior colliculus, not an extended fixation zone, can account for the remote distractor effect, Behavioral and Brain Sciences, vol.22, issue.4, pp.694-695, 1999. ,
DOI : 10.1017/S0140525X99432157
A field theory of saccade generation: Temporal-to-spatial transform in the superior colliculus, Vision Research, vol.35, issue.23-24, pp.23-243313, 1995. ,
DOI : 10.1016/0042-6989(95)00129-3
Metrics of saccade responses to visual double stimuli: Two different modes, Vision Research, vol.24, issue.10, pp.1169-1179, 1984. ,
DOI : 10.1016/0042-6989(84)90172-X
Visuomotor fields of the superior colliculus: A quantitative model, Vision Research, vol.26, issue.6, pp.857-873, 1986. ,
DOI : 10.1016/0042-6989(86)90144-6
Eye movements evoked by collicular stimulation in the alert monkey, Vision Research, vol.12, issue.11, pp.1795-1808, 1972. ,
DOI : 10.1016/0042-6989(72)90070-3
Emergence of attention within a neural population, Neural Networks, vol.19, issue.5, pp.573-581, 2006. ,
DOI : 10.1016/j.neunet.2005.04.004
URL : https://hal.archives-ouvertes.fr/inria-00000143
A model of multiplicative neural responses in parietal cortex., Proceedings of the National Academy of Sciences, vol.93, issue.21, pp.956-11961, 1996. ,
DOI : 10.1073/pnas.93.21.11956
Single-unit recording and stimulation in superior colliculus of the alert rhesus monkey, Journal of Neurophysiology, vol.35, issue.6, pp.915-924, 1972. ,
A neural field model for saccade planning in the superior colliculus: speed-accuracy tradeoff in the double-target paradigm, Neurocomputing, vol.44, issue.46, pp.623-628, 2002. ,
DOI : 10.1016/S0925-2312(02)00449-6
A model of the internal control system within the superior colliculus, Biomedical Sciences Instrumentation, vol.37, pp.349-354, 2001. ,
Movement fields of saccade-related burst neurons in the monkey superior colliculus, Brain Research, vol.190, issue.1, pp.39-50, 1980. ,
DOI : 10.1016/0006-8993(80)91158-0
Size and distribution of movement fields in the monkey superior colliculus, Brain Research, vol.113, issue.1, pp.21-34, 1976. ,
DOI : 10.1016/0006-8993(76)90003-2
Population Coding of the Direction, Amplitude, and Velocity of Saccadic Eye Movements by Neurons in the Superior Colliculus, Cold Spring Harbor Symposia on Quantitative Biology, vol.55, issue.0, pp.805-811, 1990. ,
DOI : 10.1101/SQB.1990.055.01.075
A global effect of capture saccades, Experimental Brain Research, vol.78, issue.1, pp.57-65, 2011. ,
DOI : 10.1007/s00221-011-2602-6
Neural 'bubble' dynamics in two dimensions: foundations, Biological Cybernetics, vol.80, issue.6, pp.393-409, 1999. ,
DOI : 10.1007/s004220050534
A Model of Saccade Initiation Based on the Competitive Integration of Exogenous and Endogenous Signals in the Superior Colliculus, Journal of Cognitive Neuroscience, vol.78, issue.2, pp.256-271, 2001. ,
DOI : 10.1007/BF00207285
The Effects of Remote Distractors on Saccade Programming, Perception, vol.25, issue.1 suppl, pp.1108-1119, 1997. ,
DOI : 10.1068/v96l0305
The macaque midbrain reticular formation sends side-specific feedback to the superior colliculus, Experimental Brain Research, vol.189, issue.1, pp.701-717, 2010. ,
DOI : 10.1007/s00221-009-2090-0
Differential effects of non-target stimuli on the occurrence of express saccades in man, Vision Research, vol.34, issue.14, 1994. ,
DOI : 10.1016/0042-6989(94)90312-3
A mathematical theory of the functional dynamics of cortical and thalamic nervous tissue, Kybernetik, vol.12, issue.2, pp.55-80, 1973. ,
DOI : 10.1007/BF00288786
Activity of superior colliculus in behaving monkey. iii. cells discharging before eye movements, Journal of Neurophysiology, vol.35, issue.4, pp.575-586, 1972. ,
Eye movements and vision Zénon A, Krauzlis RJ (2012) Attention deficits without cortical neuronal deficits, Nature, vol.489, issue.7416, pp.434-437, 1967. ,
