Modelling and control of a travelling wave in a finite beam, using multi-modal approach and vector control method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
—This paper presents a new method to produce and control the vibration amplitude and direction of a travelling wave in a finite beam, using multi-modal approach. A closed loop control of the transducer vibration is applied using vector control method. the modelling in rotating frame and the decoupling according to two-axis allows to obtain a double independent closed loop control. This allows to regulate the vibration amplitude of the travelling wave directly. An analytical modelling is presented, with experimental validation, showing good performances even in the presence of perturbations.
GHENNA_Sofiane_IFCS-EFTF.pdf (781.32 Ko) Télécharger le fichier
hal-01201877 , version 1 (18-09-2015)
Sofiane Ghenna, Frédéric Giraud, Christophe Giraud-Audine, Michel Amberg, Betty Lemaire-Semail. Modelling and control of a travelling wave in a finite beam, using multi-modal approach and vector control method. IEEE International Frequency Control Symposium & European Frequency and Time Forum will, Apr 2015, Denver, Colorado, USA,, United States. ⟨10.1109/FCS.2015.7138895⟩. ⟨hal-01201877⟩
227 Consultations
352 Téléchargements
