Layer-averaged Euler and Navier-Stokes equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
In this paper we propose a strategy to approximate incompressible free surface Euler and Navier-Stokes models. The main advantage of the proposed models is that the water depth is a dynamical variable of the system and hence the model is formulated over a fixed domain. The proposed strategy extends previous works approximating the Euler and Navier-Stokes systems using a multilayer description. Here, the needed closure relations are obtained using an energy-based optimality criterion instead of an asymptotic expansion. Moreover, the layer-averaged description is successfully applied to the Navier-Stokes system with a general form of the Cauchy stress tensor.
ns_hydro.pdf (433.47 Ko) Télécharger le fichier
hal-01202042 , version 1 (18-09-2015)
hal-01202042 , version 2 (21-09-2015)
hal-01202042 , version 3 (27-06-2016)
Marie-Odile Bristeau, Bernard Di Martino, Cindy Guichard, Jacques Sainte-Marie. Layer-averaged Euler and Navier-Stokes equations. 2015. ⟨hal-01202042v2⟩
628 Consultations
425 Téléchargements
