Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : In this paper we propose a strategy to approximate incompressible hydrostatic free surface Euler and Navier-Stokes models. The main advantage of the proposed models is that the water depth is a dynamical variable of the system and hence the model is formulated over a fixed domain.
The proposed strategy extends previous works approximating the Euler and Navier-Stokes systems using a multilayer description. Here, the needed closure relations are obtained using an energy-based optimality criterion instead of an asymptotic expansion. Moreover, the layer-averaged description is successfully applied to the Navier-Stokes system with a general form of the Cauchy stress tensor.
Marie-Odile Bristeau, Cindy Guichard, Bernard Di Martino, Jacques Sainte-Marie. Layer-averaged Euler and Navier-Stokes equations. Communications in Mathematical Sciences, International Press, 2017, ⟨10.4310/CMS.2017.v15.n5.a3⟩. ⟨hal-01202042v3⟩
