Reports
TABARNAC: Tools for Analyzing Behavior of Applications Running on NUMA Architecture
Abstract : In modern parallel architectures, memory accesses represent a common bottleneck. Thus, optimizing the way applications access the memory is an important way to improve performance and energy consumption. Memory accesses are even more important with NUMA machines, as the access time to data depends on its location in the memory. Many efforts were made to develop adaptive tools to improve memory accesses at the runtime by optimizing the mapping of data and threads to NUMA nodes. However, theses tools are not able to change the memory access pattern of the original application, therefore a code written without considering memory performance might not benefit from them. Moreover, automatic mapping tools take time to converge towards the best mapping, losing optimization opportunities. A deeper understanding of the memory behavior can help optimizing it, removing the need for runtime analysis. In this paper, we present TABARNAC, a tool for analyzing the memory behavior of parallel applications with a focus on NUMA architectures. TABARNAC provides a new visualization of the memory access behavior, focusing on the distribution of accesses by thread and by structure. Such visualization allows the developer to easily understand why performance issues occur and how to fix them. Using TABARNAC, we explain why some applications do not benefit from data and thread mapping. Moreover, we propose several code modifications to improve the memory access behavior of several parallel applications.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01202105
Contributor : David Beniamine Connect in order to contact the contributor
Submitted on : Friday, September 18, 2015 - 4:56:06 PM
Last modification on : Wednesday, July 6, 2022 - 4:12:37 AM
Long-term archiving on: : Tuesday, December 29, 2015 - 8:46:12 AM
File
tabarnac.pdf
Identifiers
  • HAL Id : hal-01202105, version 1
Collections
Citation
David Beniamine, Matthias Diener, Guillaume Huard, Philippe Olivier Alexandre Navaux. TABARNAC: Tools for Analyzing Behavior of Applications Running on NUMA Architecture. [Research Report] 8774, Inria Grenoble Rhône-Alpes, Université de Grenoble. 2015, pp.24. ⟨hal-01202105⟩
Share
Metrics
Record views
162
Files downloads
313
