Glass+Skin: An Empirical Evaluation of the Added Value of Finger Identification to Basic Single-Touch Interaction on Touch Screens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yves Guiard
Gilles Bailly
Éric Lecolinet
Olivier Rioul
The usability of small devices such as smartphones or interactive watches is often hampered by the limited size of command vocabularies. This paper is an attempt at better understanding how finger identification may help users invoke commands on touch screens, even without recourse to multi-touch input. We describe how finger identification can increase the size of input vocab‐ ularies under the constraint of limited real estate, and we discuss some visual cues to communicate this novel modality to novice users. We report a controlled experiment that evaluated, over a large range of input-vocabulary sizes, the effi‐ ciency of single-touch command selections with vs. without finger identification. We analyzed the data not only in terms of traditional time and error metrics, but also in terms of a throughput measure based on Shannon’s theory, which we show offers a synthetic and parsimonious account of users’ performance. The results show that the larger the input vocabulary needed by the designer, the more prom‐ ising the identification of individual fingers.
346948_1_En_5_Chapter.pdf (644.3 Ko) Télécharger le fichier
hal-01202852 , version 1 (05-10-2017)
hal-01202852 , version 2 (23-01-2019)
Paternité
Quentin Roy, Yves Guiard, Gilles Bailly, Éric Lecolinet, Olivier Rioul, et al.. Glass+Skin: An Empirical Evaluation of the Added Value of Finger Identification to Basic Single-Touch Interaction on Touch Screens. 15th Human-Computer Interaction (INTERACT), Sep 2015, Bamberg, Germany. pp.55-71, ⟨10.1007/978-3-319-22723-8_5⟩. ⟨hal-01202852v1⟩
323 Consultations
171 Téléchargements
