Arrangements and their applications, Handbook of Computational Geometry, pp.49-119, 1998. ,
Fast, Exact, Linear Booleans, Computer Graphics Forum, vol.13, issue.1, pp.1269-1278, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01504.x
Robust regularized set operations on polyhedra, Proceedings of the Twenty-Fourth Annual Hawaii International Conference on System Sciences, pp.691-700, 1991. ,
DOI : 10.1109/HICSS.1991.183943
Exact and Robust (Self-)Intersections for Polygonal Meshes, Computer Graphics Forum, vol.28, issue.3, pp.397-406, 2010. ,
DOI : 10.1111/j.1467-8659.2009.01609.x
A generic lazy evaluation scheme for exact geometric computations, Proc. 2nd Library-Centric Software Design, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00089229
Practical volumetric sculpting. The Visual Computer 16, pp.469-480, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00510075
Polyhedral modelling with multiprecision integer arithmetic, Computer-Aided Design, vol.29, issue.2, pp.123-133, 1997. ,
DOI : 10.1016/S0010-4485(96)00041-3
Static analysis yields efficient exact integer arithmetic for computational geometry, ACM Transactions on Graphics, vol.15, issue.3, pp.223-248, 1996. ,
DOI : 10.1145/231731.231735
Adaptively sampled distance fields, Proceedings of the 27th annual conference on Computer graphics and interactive techniques , SIGGRAPH '00, pp.249-254, 2000. ,
DOI : 10.1145/344779.344899
Boolean operations on 3D selective Nef complexes: Data structure, algorithms, optimized implementation and experiments, Computational Geometry, vol.38, issue.1-2, pp.64-99, 2007. ,
DOI : 10.1016/j.comgeo.2006.11.009
Geometric and solid modeling: an introduction, 1989. ,
Robust set operations on polyhedral solids, IEEE Computer Graphics and Applications, vol.9, issue.6, pp.50-59, 1989. ,
DOI : 10.1109/38.41469
Dual contouring of hermite data, ACM Trans. Graph, vol.21, 2002. ,
Feature sensitive surface extraction from volume data, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.57-66, 2001. ,
DOI : 10.1145/383259.383265
Constructive solid geometry for polyhedral objects, ACM SIGGRAPH Computer Graphics, vol.20, issue.4, pp.161-170, 1986. ,
DOI : 10.1145/15886.15904
An Introduction to Solid Modeling, 1988. ,
FPG: A code generator for fast and certified geometric predicates, Real Numbers and Computers, pp.47-60, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00344297
Level set surface editing operators, ACM Trans. Graph, vol.21, 2002. ,
DOI : 10.1145/566570.566585
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.674.5626
Merging BSP trees yields polyhedral set operations, ACM SIGGRAPH Computer Graphics, vol.24, issue.4, pp.115-124, 1990. ,
DOI : 10.1145/97880.97892
Hybrid Booleans, Computer Graphics Forum, vol.24, issue.2, pp.75-87, 2010. ,
DOI : 10.1111/j.1467-8659.2009.01545.x
Representations for Rigid Solids: Theory, Methods, and Systems, ACM Computing Surveys, vol.12, issue.4, pp.437-464, 1980. ,
DOI : 10.1145/356827.356833
Boolean operations in solid modeling: Boundary evaluation and merging algorithms, Proceedings of the IEEE, pp.30-44, 1985. ,
DOI : 10.1109/PROC.1985.13108
Scalable GPU rendering of CSG models, Computers & Graphics, vol.32, issue.5, pp.526-539, 2008. ,
DOI : 10.1016/j.cag.2008.06.002
Note the rich topology (unboundedness, disconnectedness, non-manifoldness) of the handled input/output meshes. Models Armadillo52kf' and NonManifoldGrid3kf' are rotated version of the original ones ,
Using tolerances to guarantee valid polyhedral modeling results, ACM SIGGRAPH Computer Graphics, vol.24, issue.4, pp.105-114, 1990. ,
DOI : 10.1145/97880.97891
The nature and meaning of perturbations in geometric computing, Discrete & Computational Geometry, vol.19, 1998. ,
Chapter 20 -Solid Modeling, Handbook of Computer Aided Geometric Design, pp.473-518, 2002. ,
Adaptive Precision Floating-Point Arithmetic and Fast Robust Geometric Predicates, Discrete & Computational Geometry, vol.18, issue.3, pp.305-363, 1997. ,
DOI : 10.1007/PL00009321
Lecture notes on geometric robustness, 2009. ,
A solid modelling system free from topological inconsistency, Journal of Information Processing, vol.12, pp.380-393, 1990. ,
Set operations on polyhedra using binary space partitioning trees, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.153-162, 1987. ,
DOI : 10.1145/37402.37421
Approximate boolean operations on large polyhedral solids with partial mesh reconstruction. Visualization and Computer Graphics, IEEE Transactions on, vol.17, pp.836-849, 2011. ,
Parallel and efficient Boolean on polygonal solids, The Visual Computer, vol.42, issue.6, pp.507-517, 2011. ,
DOI : 10.1007/s00371-011-0571-1
FAST SOFTWARE FOR BOX INTERSECTIONS, International Journal of Computational Geometry & Applications, vol.12, issue.01n02, pp.143-172, 2002. ,
DOI : 10.1142/S0218195902000785
