New interface
Conference papers
Deciphering the language of fungal pathogen recognition receptors
Witold Dyrka 1, 2, 3 Pascal Durrens 1, 4 Mathieu Paoletti 3 Sven J Saupe 3 David James Sherman 4, 1
1 MAGNOME - Models and Algorithms for the Genome
Inria Bordeaux - Sud-Ouest, UB - Université de Bordeaux, CNRS - Centre National de la Recherche Scientifique : UMR5800
4 PLEIADE - from patterns to models in computational biodiversity and biotechnology
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, BioGeCo - Biodiversité, Gènes & Communautés
Abstract : The immune system searches for pathogen invasion markers, which include pathogen proteins and host proteins modified in the course of the invasion. While some pathogen-associated molecular patterns are relatively invariant, numerous pathogen-specific markers change quickly. Therefore, to win the arms race with pathogens, host recognition receptors must adapt quickly to varied and modulating markers. To achieve this goal, the recognition domain of the receptor requires the capacity to recognize diverse possible pathogen molecule epitopes, and ability to quickly learn new ones. In plants and fungi, which lack an adaptive immune system, this key role in the immunity is played by the NLR family of receptors, which adapt to ever-changing pathogen-specific invasion markers thanks to their repeat-based architecture, which can produce diversity of recognition paratopes through unequal crossing-over and mutation [1]. The unequal crossing-over is a repeat shuffling process 10,000 to 100,000 times quicker than the standard point mutation, however it requires (and promotes) high sequence similarity between consecutive repeat units. At the same time certain positions in the repeats are highly variable under positive diversifying selection; they are believed to form the actual recognition paratope [2, 3]. Characterizing computationally the language of these pathogen recognition receptors can provide insight into the molecular mechanisms of immune response and describe the limits of the pathogen targets that can be recognized. In this work, we modeled generation and selection of the recognition paratopes as a stochastic string rewriting system with constraints, tuned by analysis of observed evolutionary processes and validated with regard to a large data set of fungal NLR [3]. First, we cross-checked the unequal crossing-over and mutation model with the existing experimental data. Second, we analyzed mathematical properties of the model and showed that its convergence to stationary distribution. Then, we compared real and simulated data. Among others, analyzing the feasible set of solutions revealed that the model explained the i=i+2 (even-odd) periodicity observed in the repeat number distribution of a family of receptors. Next, we explored discrepancies between real and simulated data in order to discover constraints acting on the paratopes. For example, by comparing amino acid content in the model and original populations, we confirmed that highly variable sites identified on the basis of entropy, were subject to constraints towards composition typical for binding sites, which was coherent with the suggested role of recognition paratopes. Finally, we proposed an interactive approach to exploring the solution space of amino acid repeats by means of 2-d projections and significance tests in sectors of the space. In a preliminary analysis, we found an overrepresented pattern R-[SYQFW](1,3)-R at one of the highly variable positions in a family of receptors, which potentially has functional importance. The methodology developed in this work is general and therefore can be applied to any class of amino acid repeats generated by unequal crossing-over for which an equivalent high quality data set is available. An appealing future application of our model would be testing of hypotheses regarding repeat origin or function encoded as constraints on the string rewriting system. [1] M.Paoletti, S.J.Saupe. BioEssays, 2009, 31:1201-1210 [2] M.Paoletti, S.J.Saupe, C.Clave, PLoS ONE, 2007, 2:e283 [3] W.Dyrka, M.Lamacchia, P.Durrens, B.Kobe, A.Daskalov, M.Paoletti, D.J.Sherman, S.Saupe, Gen Biol Evol, 2014, 6, 3137-3158.
Document type :
Conference papers
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01203357
Contributor : Witold Dyrka Connect in order to contact the contributor
Submitted on : Friday, September 25, 2015 - 10:32:10 AM
Last modification on : Tuesday, September 6, 2022 - 1:20:34 PM
Long-term archiving on: : Tuesday, December 29, 2015 - 9:24:05 AM
File
Abstract_wdyrka.pdf
Identifiers
  • HAL Id : hal-01203357, version 1
Collections
Citation
Witold Dyrka, Pascal Durrens, Mathieu Paoletti, Sven J Saupe, David James Sherman. Deciphering the language of fungal pathogen recognition receptors. 8th Symposium of the Polish Bioinformatics Society, Polish Bioinformatics Society, Sep 2015, Lublin, Poland. ⟨hal-01203357⟩
Share
Metrics
Record views
299
Files downloads
68
