A taxonomy for conjugate gradient methods, J. Numer. Anal, vol.27, pp.1542-1568, 1990. ,
Mixed-integer quadrangulation, ACM Trans. Graph, vol.28, issue.77, pp.1-7710, 2009. ,
The maximum clique problem, Handbook of Combinatorial Optimization 4. Kluwer Academic, 1999. ,
A frontal approach to hexdominant mesh generation, Advanced Modeling and Simulation in Engineering Sciences, vol.1, issue.1, 2014. ,
Simulation of simplicity, 1990. ,
Fully automatic mesh generator for 3d domains of any shape, IMPACT Comput. Sci. Eng, vol.2, issue.3, pp.187-218, 1990. ,
All-hex mesh generation via volumetric polycube deformation, Computer Graphics Forum (Special Issue of Symposium on Geometry Processing, vol.30, issue.5, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00766792
Boundary aligned smooth 3d cross-frame field, ACM Trans. Graph, vol.30, issue.143, pp.1-1438, 2011. ,
Frame field singularity correction for automatic hexahedralization, IEEE Transactions on Visualization and Computer Graphics, vol.20, issue.8, pp.1189-1199, 2014. ,
Quadcover ? surface parameterization using branched coverings, Computer Graphics Forum, vol.26, issue.3, pp.375-384, 2007. ,
All-hex meshing using singularity-restricted field, ACM Trans. Graph, vol.31, issue.177, pp.1-17711, 2012. ,
Polycut: Monotone graph-cuts for polycube base-complex construction OPENNL, Open Numerical Library, Proc. SIGGRAPH ASIA 2013) 32, 1968. ,
There are four possible ways of assembling prisms of type For each configuration, a sliver can be inserted between the two prisms (graphs on the right) ,
Among the six decompositions into 5 or 6 tetrahedra, two of them cannot be split into 2 prisms. The one with six tetrahedra (right) can be deduced from the one with five tetrahedra (left) by applying a flip-2-3 operation to any pair of tetrahedra that share a facet GEOGRAM, a programming library of geometric algorithms, 2015. ,
Lp centroidal voronoi tesselation and its applicationsSIGGRAPH conference proceedings). patent pending -FR, ACM Transactions on Graphics, vol.10, 2010. ,
Generating a mixed mesh of hexahedra , pentahedra and tetrahedra from an underlying tetrahedral mesh, International Journal for Numerical Methods in Engineering, vol.49, pp.1-2, 2000. ,
FPG: A code generator, Real Numbers and Computers, pp.47-60, 2008. ,
The " hex-tet " hex-dominant meshing algorithm as implemented in cubit, CUBIT; Proceedings, 7 th International Meshing Roundtable 98, pp.151-158, 1998. ,
Cubecover? parameterization of 3d volumes, Computer Graphics Forum, vol.30, issue.5, pp.1397-1406, 2011. ,
Periodic global parameterization, ACM Trans. Graph, vol.25, issue.4, pp.1460-1485, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00104853
On smooth 3d frame field design, 2015. ,
Hexahedral mesh generation constraints, Eng. with Comput, vol.24, issue.3, pp.195-213, 2008. ,
Fully-automated hex-dominant mesh generation with directionality control via packing rectangular solid cells, International Journal for Numerical Methods in Engineering, vol.57, issue.15, pp.2099-2129, 2003. ,
Isotropic remeshing with fast and exact computation of restricted voronoi diagram, ACM/EG Symposium on Geometry Processing / Computer Graphics Forum, 2009. ,
