Recipes for stable linear embeddings from Hilbert spaces to $\mathbb{R}^m$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We consider the problem of constructing a linear map from a Hilbert space $\mathcal{H}$ (possibly infinite dimensional) to $\mathbb{R}^m$ that satisfies a restricted isometry property (RIP) on an arbitrary signal model $\mathcal{S} \subset \mathcal{H}$. We present a generic framework that handles a large class of low-dimensional subsets but also \emph{unstructured} and \emph{structured} linear maps. We provide a simple recipe to prove that a random linear map satisfies a general RIP on $\mathcal{S}$ with high probability. We also describe a generic technique to construct linear maps that satisfy the RIP. Finally, we detail how to use our results in several examples, which allow us to recover and extend many known compressive sampling results.
IEEE_TIT-Embeddings_infinite_dimension.pdf (621.82 Ko) Télécharger le fichier
hal-01203614 , version 1 (23-09-2015)
hal-01203614 , version 2 (17-01-2017)
  • HAL Id : hal-01203614 , version 1
Gilles Puy, Mike E. Davies, Rémi Gribonval. Recipes for stable linear embeddings from Hilbert spaces to $\mathbb{R}^m$. 2015. ⟨hal-01203614v1⟩
426 Consultations
387 Téléchargements
