G. Ward, Graphics Gems II, pp.80-83, 1991.
R. Bogart, F. Kainz, and D. Hess, OpenEXR image file format, ACM Siggraph, Sketches & Applications, pp.836-844, 2003.
F. Banterle, K. Debattista, P. Ledda, and A. Chalmers, A gpu-friendly method for high dynamic range texture compression using inverse tone mapping, Proceedings of graphics interface, pp.41-48, 2008.
Z. Mai, H. Mansour, R. Mantiuk, P. Nasiopoulos, R. K. Ward et al., Optimizing a tone curve for backward-compatible high dynamic range image and video compression, IEEE Trans. Image Process, vol.20, issue.6, pp.1558-1571, 2011.
Y. Li, L. Sharan, and E. H. Adelson, Compressing and companding high dynamic range images with subband architectures, Proceedings of SIGGRAPH, pp.836-844, 2005.
DOI : 10.1145/1186822.1073271
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.6622
T. Jinno, M. Okuda, and N. Adami, New local tone mapping and two-layer coding for HDR images, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.765-768, 2012.
DOI : 10.1109/ICASSP.2012.6287996
G. Ward and M. Simmons, JPEG-HDR: A backwards-compatible, high dynamic range extension to jpeg compatible high dynamic range MPEG video compression, Proceedings of the Thirteenth Color Imaging Conference, pp.283-290, 2005.
T. Richter, On the standardization of the JPEG XT image compression, 2013 Picture Coding Symposium (PCS), pp.37-40, 2013.
DOI : 10.1109/PCS.2013.6737677
C. Lee and C. Kim, Rate-distortion optimized layered coding of high dynamic range videos, Journal of Visual Communication and Image Representation, vol.23, issue.6, pp.908-923, 2012.
DOI : 10.1016/j.jvcir.2012.05.009
M. Okuda and N. Adami, Two-layer coding algorithm for high dynamic range images based on luminance compensation, Journal of Visual Communication and Image Representation, vol.18, issue.5, pp.377-386, 2007.
DOI : 10.1016/j.jvcir.2007.06.004
T. Wiegand, G. J. Sullivan, B. Bjontegaard, and A. Luthra, Overview of the H.264/AVC video coding standard, IEEE Transactions on Circuits and Systems for Video Technology, vol.13, issue.7, pp.13-20, 2003.
DOI : 10.1109/TCSVT.2003.815165
G. J. Sullivan, J. Ohm, W. Han, and T. Wiegand, Overview of the High Efficiency Video Coding (HEVC) Standard, IEEE Transactions on Circuits and Systems for Video Technology, vol.22, issue.12, pp.1649-1668, 2012.
DOI : 10.1109/TCSVT.2012.2221191
M. Winken, D. Marpe, H. Schwarz, and T. Wiegand, Bit-Depth Scalable Video Coding, 2007 IEEE International Conference on Image Processing, pp.5-8, 2007.
DOI : 10.1109/ICIP.2007.4378877
M. Takeuchi, Y. Matsuo, Y. Yamamura, J. Katto, and K. Iguchi, A bit-depth scalable video coding approach considering spatial gradation restoration, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.1373-1376, 2012.
DOI : 10.1109/ICASSP.2012.6288146
S. Liu, W. Kim, and A. Vetro, Bit-depth scalable coding for high dynamic range video, Visual Communications and Image Processing 2008, 2008.
DOI : 10.1117/12.766601
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.417.6275
J. Garbas and H. Thoma, Inter-layer prediction for backwards compatible high dynamic range video coding with SVC, 2012 Picture Coding Symposium, pp.285-288, 2012.
DOI : 10.1109/PCS.2012.6213348
M. L. Pendu, C. Guillemot, and D. Thoreau, Template based inter-layer prediction for high dynamic range scalable compression, 2015 IEEE International Conference on Image Processing (ICIP), 2015.
DOI : 10.1109/ICIP.2015.7351348
URL : https://hal.archives-ouvertes.fr/hal-01204715
S. Miller, M. Nezamabadi, and S. Daly, Perceptual signal coding for more efficient usage of bit codes, SMPTE Motion Imaging Journal, 2012.
S. St, High dynamic range electro-optical transfer function of mastering reference displays HM range extension, 2014.
R. Mantiuk, K. Myszkowski, and H. Seidel, A perceptual framework for contrast processing of high dynamic range images
R. Fattal, D. Lischinski, and M. Werman, Gradient domain high dynamic range compression, ACM Trans. Graph, vol.21, issue.3, pp.249-256, 2002.
DOI : 10.1145/566570.566573
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.164.867
S. N. Pattanaik, J. Tumblin, H. Yee, D. P. Greenberg, R. Mantiuk et al., Timedependent visual adaptation for fast realistic image display pfstools hdr image gallery, Proceedings of the 27th Annual Conference on Computer Graphics and Interactive Techniques High dynamic range image examples, pp.47-54, 2000.
G. Krawczyk and R. Mantiuk, pfstmo tone mapping library
Z. Wang, A. C. Bovik, H. R. Sheikh, and E. P. Simoncelli, Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, pp.600-612, 2004.
DOI : 10.1109/TIP.2003.819861
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.2477
G. Bjontegaard, V. , and I. Meeting, Calculation of average PSNR differences between RD curves, 2001.
M. Narwaria, R. K. Mantiuk, M. P. Da, P. L. Silva, and . Callet, HDR-VDP-2.2: a calibrated method for objective quality prediction of high-dynamic range and standard images, Journal of Electronic Imaging, vol.24, issue.1, p.10501, 2015.
DOI : 10.1117/1.JEI.24.1.010501
URL : https://hal.archives-ouvertes.fr/hal-00951337
