Robustness of Homogeneous Systems with Respect to Time-Varying Perturbations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
The problem of stability robustness with respect to time-varying perturbations of a given frequency spectrum is studied applying homogeneity framework. The notion of finite-time stability over time intervals of finite length, i.e. short-finite-time stability, is introduced and used for that purpose. The results are applied to analyze the Super-Twisting algorithm behavior under some time-varying perturbations, and to demonstrate some robustness properties of the three-tank system. Some simulation examples illustrate these robustness properties.
Homogeneity_LTV_Robustness_TR.pdf (1 Mo) Télécharger le fichier
hal-01204800 , version 1 (24-09-2015)
  • HAL Id : hal-01204800 , version 1
Rios Hector, Denis Efimov, Wilfrid Perruquetti. Robustness of Homogeneous Systems with Respect to Time-Varying Perturbations. [Research Report] Inria Lille; Non-A team. 2015. ⟨hal-01204800⟩
180 Consultations
217 Téléchargements
