Energyaware checkpointing of divisible tasks with soft or hard deadlines, International Green Computing Conference (IGCC), pp.1-8, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00857244
Unified model for assessing checkpointing protocols at extreme-scale. Concurrency and Computation: Practice and Experience, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00696154
Redesigning the message logging model for high performance, Concurrency and Computation: Practice and Experience, vol.22, issue.16, pp.2196-2211, 2010. ,
Grid'5000: A Large Scale, Reconfigurable, Controlable and Monitorable Grid Platform, IEEE/ACM Grid 2005, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000284
Preventive migration vs. preventive checkpointing for extreme scale supercomputers, Parallel Processing Letters, vol.21, issue.2, pp.111-132, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00945068
Toward exascale resilience, International Journal of High Performance Computing Applications, vol.23, pp.374-388, 2009. ,
Distributed snapshots: Determining global states of distributed systems, In Transactions on Computer Systems, vol.3, issue.1, pp.63-75, 1985. ,
A higher order estimate of the optimum checkpoint interval for restart dumps, FGCS, vol.22, issue.3, pp.303-312, 2004. ,
A higher order estimate of the optimum checkpoint interval for restart dumps, Future Generation Comp. Syst, vol.22, issue.3, pp.303-312, 2006. ,
The green grid5000: Instrumenting a grid with energy sensors, 5th International Workshop on Distributed Cooperative Laboratories: Instrumenting the Grid (IN-GRID 2010), 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00690638
An analysis of power consumption logs from a monitored grid site, IEEE/ACM International Conference on Green Computing and Communications (GreenCom-2010), pp.61-68, 2010. ,
URL : https://hal.archives-ouvertes.fr/ensl-00579429
Solving some mysteries in power monitoring of servers: Take care of your wattmeters! In, Energy Efficiency in Large Scale Distributed Systems (EE-LSDS), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00806504
Your Cluster is not Power Homogeneous: Take Care when Designing Green Schedulers! In 4 th IEEE, ternational Green Computing Conference (IGCC), 2013. ,
Energy considerations in checkpointing and fault tolerance protocols, DSNW, pp.1-6, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00748006
ECOFIT: A Framework to Estimate Energy Consumption of Fault Tolerance protocols during HPC executions, 13th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing (CCGrid), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00806500
Ecofit: A framework to estimate energy consumption of fault tolerance protocols for HPC applications, CCGRID, pp.522-529, 2013. ,
Energy efficiency in high-performance computing with and without knowledge of applications and services, International Journal of High Performance Computing Applications (IJHPCA), 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00870615
The international exascale software project: a call to cooperative action by the global high-performance community, Int. Journal of High Performance Computing Applications, vol.23, issue.4, pp.309-322, 2009. ,
Revisiting the double checkpointing algorithm, 15th Workshop on Advances in Parallel and Distributed Computational Models APDCM 2013, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00925168
A Survey of Rollback-Recovery Protocols in Message-Passing Systems, ACM Computing Surveys, vol.34, issue.3, pp.375-408, 2002. ,
Utilization driven poweraware parallel job scheduling, Computer Science -Research and Development, vol.25, issue.3-4, pp.207-216, 2010. ,
Green supercomputing comes of age, IT Professional, vol.10, issue.1, pp.17-23, 2008. ,
Evaluating the Viability of Process Replication Reliability for Exascale Systems, Proceedings of the, 2011. ,
, ACM/IEEE Conference on Supercomputing, 2011.
Analyzing the energy-time trade-off in high-performance computing applications, IEEE Trans. Parallel Distrib. Syst, vol.18, issue.6, pp.835-848, 2007. ,
Power Management in Grid Computing with Xen, Frontiers of High Performance Computing and Networking -ISPA 2006 Workshops, ISPA 2006 International Workshops, vol.4331, pp.407-416, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00441366
Energy consumption of residential and professional switches, IEEE CSE, 2009. ,
Profile-based optimization of power performance by using dynamic voltage scaling on a pc cluster, Proceedings of the 20th International in Parallel and Distributed Processing Symposium, 2006. ,
Towards efficient supercomputing: A quest for the right metric, Proceedings of the High Performance Power-Aware Computing Workshop, 2005. ,
A power-aware run-time system for highperformance computing, Proceedings of the ACM/IEEE SC 2005 Conference, 2005. ,
The international ExaScale software project roadmap, Int. J. of High Performance Computing & Applications, vol.25, issue.1, 2011. ,
Energy based performance tuning for large scale high performance computing systems, Proceedings of the 2012 Symposium on High Performance Computing, HPC '12, vol.6, pp.1-6, 2012. ,
A power benchmarking framework for network devices, NETWORKING 2009 Conference, pp.795-808, 2009. ,
Assessing Energy Efficiency of Fault Tolerance Protocols for HPC Systems, Proceedings of the 2012 IEEE 24th International Symposium on Computer Architecture and High Performance Computing (SBAC-PAD 2012), 2012. ,
Necessary and sufficient conditions for consistent global snapshots, IEEE Transactions on Parallel and Distributed Systems, vol.6, issue.2, pp.165-169, 1995. ,
Hiding checkpoint overhead in HPC applications with a semi-blocking algorithm, Proc. 2012 IEEE Int. Conf. Cluster Computing, 2012. ,
Save Watts in your Grid: Green Strategies for Energy-Aware Framework in Large Scale Distributed Systems, ICPADS 2008 : The 14th IEEE International Conference on Parallel and Distributed Systems, 2008. ,
URL : https://hal.archives-ouvertes.fr/ensl-00474726
Energyefficient execution of dense linear algebra algorithms on multi-core processors, Cluster Computing, 2012. ,
DVFScontrol techniques for dense linear algebra operations on multi-core processors, Computer Science -R&D, vol.27, issue.4, pp.289-298, 2012. ,
Load balancing and unbalancing for power and performance in cluster-based systems, WORK-SHOP ON COMPILERS AND OPERATING SYSTEMS FOR LOW POWER, 2001. ,
A 1 PB/s file system to checkpoint three million MPI tasks, Proceedings of the 22nd international symposium on High-performance parallel and distributed computing, HPDC '13, pp.143-154, 2013. ,
Linear models: Least squares and alternatives, Springer Series in Statistics, 1999. ,
Exascale software study: Software challenges in extreme scale systems, 2009. ,
Exascale computing technology challenges, VECPAR'10, the 9th Int. Conf. High Performance Computing for Computational Science, vol.6449, pp.1-25, 2011. ,
A first order approximation to the optimum checkpoint interval, Communications of the ACM, vol.17, issue.9, pp.530-531, 1974. ,
A first order approximation to the optimum checkpoint interval, Commun. ACM, vol.17, issue.9, pp.530-531, 1974. ,
A scalable double in-memory checkpoint and restart scheme towards exascale, Dependable Systems and Networks Workshops (DSN-W), 2012. ,
FTC-Charm++: an in-memory checkpointbased fault tolerant runtime for Charm++ and MPI, Proc. 2004 IEEE Int. Conf. Cluster Computing, 2004. ,
