A morphable model for the synthesis of 3D faces, SIGGRAPH, pp.187-194, 1999. ,
3D faces in motion: Fully automatic registration and statistical analysis, vol.131, pp.100-115, 2015. ,
Multilinear mdl for 3D faces, 2015. ,
Recovering non-rigid 3D shape from image streams, CVPR, vol.2, pp.690-696, 2000. ,
Multilinear wavelets: A statistical shape space for human faces, ECCV, pp.297-312, 2014. ,
Compact part-based shape spaces for dense correspondences, 2013. ,
Enhancing sparsity by reweighted l1 minimization, JFAA, vol.14, issue.5-6, pp.877-905, 2008. ,
3D point correspondence by minimum description length in feature space, ECCV, pp.621-634, 2010. ,
Building 3-d statistical shape models by direct optimization, vol.29, pp.961-981, 2010. ,
Statistical Models of Shape: Optimisation and Evaluation, 2008. ,
Statistical shape analysis, 1998. ,
A newton-grassmann method for computing the best multilinear rank-(r1, r2, r3) approximation of a tensor, SIAM J. Matrix Anal. Appl, vol.31, issue.2, pp.248-271, 2009. ,
Using image segmentation for evaluating 3D statistical shape models built with groupwise correspondence optimization, CVIU, vol.125, issue.0, pp.283-303, 2014. ,
Automatic landmark annotation and dense correspondence registration for 3D human facial images, BMC Bioinf, vol.14, issue.1, 2013. ,
Most tensor problems are NPhard, JACM, vol.60, issue.6, 2013. ,
Coregistration: Simultaneous alignment and modeling of articulated 3D shape, ECCV, pp.242-255, 2012. ,
Reshaping 3D facial scans for facial appearance modeling and 3D facial expression analysis, IVC, vol.30, issue.10, pp.750-761, 2012. ,
Multi-frame correspondence estimation using subspace constraints, Int. J. Comput. Vision, vol.48, issue.3, pp.173-194, 2002. ,
Interactive multi-resolution modeling on arbitrary meshes, SIGGRAPH, pp.105-114, 1998. ,
Tensor decompositions and applications, SIAM Rev, vol.51, issue.3, pp.455-500, 2009. ,
Automatic construction of eigenshape models by direct optimization, Image Anal, vol.2, issue.4, pp.303-314, 1998. ,
Signal processing based on multilinear algebra, 1997. ,
On the limited memory method for large scale optimization, Math. Prog.: Series A and B, vol.45, issue.3, pp.503-528, 1989. ,
Bilinear models for 3-D face and facial expression recognition, IFS, vol.3, pp.498-511, 2008. ,
Establishing point correspondence of 3D faces via sparse facial deformable model, IP, vol.22, issue.11, pp.4170-4181, 2013. ,
Using facial symmetry to handle pose variations in real-world 3D face recognition, vol.33, pp.1938-1951, 2011. ,
Fully automatic expression-invariant face correspondence, MVAP, pp.1-21, 2013. ,
Bosphorus database for 3D face analysis, BIOID, pp.47-56, 2008. ,
Tracking and modeling non-rigid objects with rank constraints, CVPR, pp.493-500, 2001. ,
Face transfer with multilinear models, SIGGRAPH, vol.24, issue.3, pp.426-433, 2005. ,
Facial expression editing in video using a temporally-smooth factorization, CVPR, pp.861-868, 2012. ,
A 3D facial expression database for facial behavior research, FG, pp.211-216, 2006. ,
