The impact of failure, repair and joint imbalance of processing time means & buffer sizes on the performance of unpaced production lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Manufacturing Technology and Management Année : 2015
"This article studies the performance of unpaced serial production lines that are subject to breakdown and are imbalanced in terms of both of their processing time means (MTs) and buffer storage capacities (BCs). Simulation results show that the best pattern in terms of throughput is a balanced line With respect to average buffer level; the best configuration is a monotone decreasing MT order, together with an ascending BC arrangement. Statistical analysis shows that BC, combined patterns of MT and BC imbalance, line length and degree of imbalance all contribute significantly to performance. [...]" Sabry Shaaban, Tom McNamara and Sarah Hudson
Impact_of_failure_2015_pre.pdf (381.37 Ko) Télécharger le fichier
hal-01205567 , version 1 (29-09-2015)
  • HAL Id : hal-01205567 , version 1
Sabry Shaaban, Tom Mcnamara, Sarah Hudson. The impact of failure, repair and joint imbalance of processing time means & buffer sizes on the performance of unpaced production lines. International Journal of Manufacturing Technology and Management, 2015. ⟨hal-01205567⟩
133 Consultations
93 Téléchargements
