A constraint on the maximum reflectance of rapidly oscillating dielectric gratings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2002
When considering optimal design problems involving diffraction gratings, it is useful to have some a priori characterization of the range of possible reflectances one can achieve for given material parameters. Here we consider the limiting case of a rapidly oscillating dielectric grating and show that such gratings can have reflectance no greater than that of a flat interface, regardless of the shape of the grating interface.
02_SICON.pdf (159.54 Ko) Télécharger le fichier
hal-01205880 , version 1 (29-09-2015)
hal-01205880 , version 2 (14-02-2017)
Gang Bao, David Dobson, Karim Ramdani. A constraint on the maximum reflectance of rapidly oscillating dielectric gratings. SIAM Journal on Control and Optimization, 2002, 40 (6), pp.1858-1866. ⟨10.1137/S036301290037435X⟩. ⟨hal-01205880v1⟩
77 Consultations
102 Téléchargements
