New interface
Conference papers
A comprehensive analysis of game-based ballot privacy definitions
Abstract : We critically survey game-based security definitions for the privacy of voting schemes. In addition to known limitations, we unveil several previously unnoticed shortcomings. Surprisingly, the conclusion of our study is that none of the existing definitions is satisfactory: they either provide only weak guarantees, or can be applied only to a limited class of schemes, or both. Based on our findings, we propose a new game-based definition of privacy which we call BPRIV. We also identify a new property which we call {\em strong consistency}, needed to express that tallying does not leak sensitive information. We validate our security notions by showing that BPRIV, strong consistency (and an additional simple property called strong correctness) for a voting scheme imply its security in a simulation-based sense. This result also yields a proof technique for proving entropy-based notions of privacy which offer the strongest security guarantees but are hard to prove directly: first prove your scheme BPRIV, strongly consistent (and correct), then study the entropy-based privacy of the result function of the election, which is a much easier task.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01206289
Contributor : Véronique Cortier Connect in order to contact the contributor
Submitted on : Monday, September 28, 2015 - 5:00:28 PM
Last modification on : Friday, January 21, 2022 - 3:09:06 AM
Links full text
Identifiers
Citation
David Bernhard, Véronique Cortier, David Galindo, Olivier Pereira, Bogdan Warinschi. A comprehensive analysis of game-based ballot privacy definitions. 36th IEEE Symposium on Security and Privacy (S&P'15), May 2015, San Jose, United States. ⟨10.1109/SP.2015.37⟩. ⟨hal-01206289⟩
Share
Metrics
Record views
197
